94 Raptor killer
Re: 94 Raptor killer
I pushed the rear back 1.5" so I had to get a longer drive shaft but that is it. It's basically the 18" most guys are getting plus 3" of up from the notch.
oh, okay, looks sweet. i like that housing!!
update- shocks mocked (again)
Click for video of cycling
Swinger finished- ImageImage
ryan B
Bronco Info: prerunner
Post by ryan B »
If you have access where your steering swinger mounts You should weld the two C's of the chassis together. Mine started pulling apart after a while, and i had to port o power it straight, and weld it.
ryan B wrote:If you have access where your steering swinger mounts You should weld the two C's of the chassis together. Mine started pulling apart after a while, and i had to port o power it straight, and weld it.
Good to know. Thanks for the heads up!
Dan88Rigid
Bronco Info: Full build by Jason Rivera from Race Truck Factory.
Post by Dan88Rigid »
Looking good. Who made the crossover steering setup?
Rigid Industries - LED Lighting http://www.rigidindustries.com/
JAMAR Brakes http://www.jamarperformance.com/
Artec Industries http://www.artecindustries.com/
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
Dan88Rigid wrote:Looking good. Who made the crossover steering setup?
Thanks! I got the pitman from Yikes at the Leduc swap meet. My buddy built the swinger and tie rods.
Update-
Brakes are on just need to plumb and install
economig
Post by economig »
N I C E !
Don't know If you posted. But what's the width of that bad boy?!
72.5", 7" over stock. I am not sure what Im gonna do for bedside. I heard fiberwerx is coming out with 5" flare this summer and McNeil has 6". I like the way the McNeil ones look I just dont know if 6" is to much. Anyone need 3" bedside? I mounted them and never ran it.
I have to rework the upper limit strap mount cause its binding at full bump everything else is dialed. 3" bedsides are going to Economig and Mcneils 6" are on order to replace them.
Just a little wide for the 3" quareters
Full tuck with the fenders out of the way
New upper limit mount
are the straps binding or the U Joint/axles?
Integrity, Money, Relevance
1amD1cker1@gmail.com
economig
Post by economig »
Looks awesome Brian! This thing is gonna have Raptors stuck in its treads and not even notice now! Ha ha
D1cker1 wrote:are the straps binding or the U Joint/axles?
The straps mount on the top of the axle and the bottom of the frame behind the notch. So when it goesto full bump the upper tabs are below the axle tabs and the strap binds on the truss. Its kinda hard to explain or picture with out seeing it. Easy fix, i'm going re do the upper mount with a heim on the inside of the frame rail. The double picture was suposed to be one of the new upper mounts I started I will fix the post later today.
economig wrote:Looks awesome Brian! This thing is gonna have Raptors stuck in its treads and not even notice now! Ha ha
I hope so I need to finish it first!! haha Never finished just in temporary working oder till the next mod, right?!
Limit strap version 3.0 complete. The upper mount is on a hiem just in from of the notch lot more room to tuck out of the way. I also went with a 2" longer strap. Pulling the rearend tonight for dis-assembly, paint and final assembly. We got the resivours mounted a swell.
Got some work done today. Buttoned up everything on the rear end. Just needs braked bled and diff fluid. Finished the tranny crossmember. I still want to tie in the suspension mounts eventually but I want to drive it more. I also made a mount for a universal guage cluster for tranny and oil temp. Sorry my cell pics arent great I will take some better ones.
Tits!!
economig
Post by economig »
L I K E ! ! !
Love tge dash!!!!
