HTO'S BRONCO BUILD
Re: HTO'S BRONCO BUILD
Thank you Tony its a 3300c.
- BajaF250
- Bronco Info: 1982 Ford F250
Hey Randy,
Wow, that looks great! Nice job! The bronco is really coming along... can't wait to check it out... haven't seen it since the Excursion once removed... over a year now... you've been putting in a ton of work and major changes... Nicely done!
Thank you Tom! I'm trying to keep up with all you guys! You should come out when we all make a trip to Barstow! Id love to see the 250 from the side instead of the rear for a change.
- BajaF250
You bet I will... I was just up there (off of Hodge rd) Wed... But I plan on hitting the Dec 1 race! Gonna help the Fogle race team!hobbyturnedobsession wrote:Thank you Tom! I'm trying to keep up with all you guys! You should come out when we all make a trip to Barstow! Id love to see the 250 from the side instead of the rear for a change.
Ill be there too helping out Kaveman!
hobbyturnedobsession wrote:Ill be there too helping out Kaveman!
Heyyyy, so will I!
- Polarcub
Not sure if were racing Dec its a bit up in the air last I talked to Matt/gary
Jeremy
- Pre Run It
- Bronco Info: 93' 5.8 glass F & B 2.5 pro series FOX with Res, Caged, bfg projects beadlocks currie
Bronco is looking good Randy.
Thank you Javier! Well its been ALOT of maintenance. A new water pump and thermostat housing, the revalve on the front shocks and after finally really noticing the buck while in Calico, a revalve in the rear. I put in what i believe they called a ride plate between the compression stack and the spacer. I also went .08 compression .12 rebound as the J40s seem to have a steep rate. I also took out a bleed screw. We'll see how it works!!
Also, i towed a trailer with a sand rail and WOW what a difference with the gearing. I cant believe how much more power i have. I also have to reseal the oil and trans dipstick tube. Has anyone ridden in the prp podium seats? I'm interested in them. Also, per Carly's christmas wish, i picked up a set of seat heaters from amazon. Those have to go in before new years.
- 93Broncobuff
Randy
Your Bronco is truely Bitchin!!!
- says the guy who is modeling some stuff after your disign/wisdom!
- bajascott
- My belly is my best friend
Seat heaters......sound good....
Dude theyre cheap. 80 bucks and they come with the pads wiring and switches. They have a low high or off switch.
- 93Broncobuff
hobbyturnedobsession wrote:Also, i towed a trailer with a sand rail and WOW what a difference with the gearing. I cant believe how much more power i have. I also have to reseal the oil and trans dipstick tube. Has anyone ridden in the prp podium seats? I'm interested in them. Also, per Carly's christmas wish, i picked up a set of seat heaters from amazon. Those have to go in before new years.
could you by chance pm me a link or the info on dem heataz.....EXtreamely interested in doin that too lol
I love that Carly's into the whole thing man, totally groovy!
Seat heaters are a good call! I plan to do them in my trucks too for Karen as that is one of the many modern conveniences she loves about new cars. I keep trying to tell her I want old looks, but with today's features.
Anyway - Philo also has the heaters. He had told me in the past they were $40 a seat.
Thats what i paid. I wish i wouldve known Philo sold em i wouldve bought them from him!
Since i revalved the shocks i thought id throw up a picture of the rear. This is with it strapped.
- uploadfromtaptalk1354848703179.jpg (38.05 KiB) Viewed 1044 times
- uploadfromtaptalk1354848696299.jpg (28.02 KiB) Viewed 1044 times
