96 chase bronco
96 chase bronco
It does sit a little higher
Integrity, Money, Relevance
1amD1cker1@gmail.com
Re: 96 chase bronco
What length shackle Chris?
cuz_im_CR
Bronco Info: 96 xlt stock
96 chase bronco
Post by cuz_im_CR »
6" camburg shackle
cuz_im_CR
96 chase bronco
Post by cuz_im_CR »
Ok so the rear cycles 18" strapped. 10" up travel and 8" down.
Things left to do before Glamis for Halloween are get my cargo area situated with jack, tire, powertank, tools and cooler mount. Then I need to tie in the core support cause it moves a ton offroad
cuz_im_CR
96 chase bronco
Post by cuz_im_CR »
Has anyone installed a 8" shackle on a bronco using the factory rear hanger? I want to lower the rear ride height down a bit as it sits to tall but don't want to waste money of it can't be done. This should also help with my negative arch a little bit.
Thanks,
Re: 96 chase bronco
I think you have to hack up the floor to put a shackle that long back there...but I may be wrong
Kel Fab Creations
Bronco Info: 95 Bronco
Re: 96 chase bronco
Post by Kel Fab Creations »
Grab a tape measure and look under your truck. I think the stock shackle is around 5" or so. You should be able to fit a +1"-2" with minimal clearancing not going through the floor.
Kelly @ Kel Fab Creations
crazyjim
Bronco Info: 2000 Jeep XJ
Re: 96 chase bronco
Post by crazyjim »
I'll probably be in the minority here, but I LOVE the way that thing is sitting... A little ass high works well surprisingly.
Re: 96 chase bronco
crazyjim wrote:I'll probably be in the minority here, but I LOVE the way that thing is sitting... A little ass high works well surprisingly.
x2
guard
Re: 96 chase bronco
Post by guard »
I think it sits very well, looks nice and balanced...
cuz_im_CR
96 chase bronco
Post by cuz_im_CR »
Yea I don't think I gonna mess with changing anything until I have it loaded down and do 1 trip on it. My thinking is my springs will settle a bit after beating on them over a weekend I the desert.
cuz_im_CR
96 chase bronco
Post by cuz_im_CR »
For some reason I just love this look so much more....
economig
96 chase bronco
Post by economig »
That does look cool ha ha!
cuz_im_CR
96 chase bronco
Post by cuz_im_CR »
Thanks, added a rigid to it...
And I bought more shoes
Dezertbronco
Bronco Info: 1990 Bronco EB
Re: 96 chase bronco
Post by Dezertbronco »
What is the aproximate cost of the Bump mounts with bolt on Strike pads?
-JD5353-
Re: 96 chase bronco
Post by -JD5353- »
You have a sweet truck. What length bar is that? think you could get any night pictures up from inside the truck?
cuz_im_CR
96 chase bronco
Post by cuz_im_CR »
-JD5353- wrote:You have a sweet truck. What length bar is that? think you could get any night pictures up from inside the truck?
The bolt on bump cans and spring plates I believe are 450 or 500$. I can't remember. If your interested I can give you contact info.
The bar is a 30" which is just temporary until my 40" arrives. As soon as I wire it up I'll take some pics and post them up.
Thanks for the compliments.
cuz_im_CR
96 chase bronco
Post by cuz_im_CR »
So here is the rim I'm considering going with. I like it cause it's something different. I'm just worried I won't like how they look after I purchase them... It sucks there is no easy way to test rims out before paying the big bucks.
Well anyways tell me all what ya think of them....
Re: 96 chase bronco
I like em! Photoshop it.
Re: 96 chase bronco
Cool looking wheel sitting there like that. Put it on a dirt truck and I don't know... I'd say photochop as well for a tester before you drop the coin
