Brian's '96
Re: Brian's '96
Somehow, I think Carmen knows the difference of building supplies to link kits and bypass shocks on the statement :lol: :lol: :lol:
Re: Brian's '96
You could just tell Carmen if you link it she can jump it further, she might actually skip the bathroom build! LOL
Re: Brian's '96
I'd secretly register the Bronco in Carmen's name, that way when there is any issue over clandestine parts purchases; "But Honey, its for YOUR car". :lol: :lol:
Re: Brian's '96
That would be like cutting my own throat.
Re: Brian's '96
yikes wrote:That would be like cutting my own throat.
Or "other body parts!" :shock:
Re: Brian's '96
Well, I actually bent the frame at the bumpstops from that hard hit in Pismo. Haha! Definitely not enough rate in the springs now that the cage is in. Wow! It's like stock all over again.
Kel Fab Creations
Bronco Info: 95 Bronco
Re: Brian's '96
Post by Kel Fab Creations »
Got any pics or video of this hard hit?
Kelly @ Kel Fab Creations
Re: Brian's '96
yikes wrote:Well, I actually bent the frame at the bumpstops from that hard hit in Pismo. Haha! Definitely not enough rate in the springs now that the cage is in. Wow! It's like stock all over again.
Damn, Brian!
Re: Brian's '96
Kel Fab Creations wrote:Got any pics or video of this hard hit?
No, but there were witnesses. The same hit took out Jeff's Bronco, sent Rick's front end almost straight up, almost caused Nick to blow out his depends and last year wasted Parish's ball joint. Haha! It caught me by surprise and didn't look as bad as it was.
Brian's '96
Also took out Jareds oil filter in the blazer...
Damn Brian!!! That sucks
Re: Brian's '96
Bent frame? Are you sure your not secretly a Raptor guy?
Re: Brian's '96
Thirteen leaves of fury!!! Should be able to jump off cliffs now. Haha!
Re: Brian's '96
BDKW1 wrote:Bent frame? Are you sure your not secretly a Raptor guy?
Too rich for my blood.
Re: Brian's '96
Baller status. 13 leafs mean your going to take down the King right b?
only1mikey
Bronco Info: 84 Bronco
Re: Brian's '96
Post by only1mikey »
How does she sit?
Mike
Re: Brian's '96
only1mikey wrote:How does she sit?
Mike
Don't know just yet. Got lazy. I asked Scott to keep it the same as it was
though.
Re: Brian's '96
I have 13 leafs in mine,it works great! You'll like it.
Re: Brian's '96
bajascott wrote:I have 13 leafs in mine,it works great! You'll like it.
Sure! Steal my thunder Scott. Haha!
Well, it does sit a little high in the back, but should settle down a little bit. Definitely feels better. Less wet noodle, but not harsh at all. Was going to hold off on the revalve, but after hitting a couple bumps, I think it will still need a bit more compression. All bleed screws are going back in too.
Re: Brian's '96
It looks Brian! Is that a race pack?
Re: Brian's '96
hobbyturnedobsession wrote:It looks Brian! Is that a race pack?
Thanks Randy. You could say that, but it's actually just a custom pack. The mains are a bit thicker. Hardly any noticeable axle wrap. Not planning to put the 2 link back on.
