95 Bronco Build!
Re: 95 Bronco Build!
Does that hood have a factory latch or require pins? Can you post (or PM) the price on that?
95 Bronco Build!
I rikey the hood!!
The hood is going to use pins. The under side only has the structure in the rear for the hinge mounts. Cost is $550. We dont have a mold for it so you're looking at $200 in custom work.
95 Bronco Build!
Couple new parts
95 Bronco Build!
Finally tore into her
Shock mount is prety much done, also picked up a C6 and transfer case today
economig
95 Bronco Build!
Post by economig »
Nice dude! I like that plate overlay
95 Bronco Build!
Looks good! I'm in the market for a c6 and transfer case!. Did you get one out of a bronco?
Ive got a shock mount identicle to to that and the side platea like to break at the point where the top plate ends at the tube. You may want to add a triangular gussett from the plate to the tube.
Andy Jones wrote:Looks good! I'm in the market for a c6 and transfer case!. Did you get one out of a bronco?
Yeah, it was out of a Bronco. I even got the floor plate with the boot for the shifter, and the front and rear drive shafts! Stoked!
hobbyturnedobsession wrote:Ive got a shock mount identicle to to that and the side platea like to break at the point where the top plate ends at the tube. You may want to add a triangular gussett from the plate to the tube.
I am definitely going to do that, this set up has to be welded in to place once it's under the truck, I'll have to do the gussets at the same time.
Exactly what mine did too. Its really easy. I shouldve seen that before. Iy looks good!
Picked up a new tow rig, the Bronco is officially a trailer queen now!
Rear suspension is done too!
Year and mileage oh the HD?
Integrity, Money, Relevance
1amD1cker1@gmail.com
04, it's got an LQ9 out of an 05 Escalade with 82K, the truck has 160k
economig
Post by economig »
Nice!
Mojo
Post by Mojo »
pics of the rear suspension done please?
Mojo's96 wrote:pics of the rear suspension done please?
It's pretty funny how easily a Bronco can hide a couple grand worth of bling. The thing looks stock!
Mojo
Post by Mojo »
that's funny! If you meant without the GLASS, I would agree!!! But it looks really good, did you put Solo shackles on it too?
