D1cker1 93 Build "The Croc"
Re: D1cker1 93 Build "The Croc"
And you learned a trick to get you by!! hahaha
Nice looking starter..... too bad I'm a cheap ass and would never buy it.
Silverslk wrote:And you learned a trick to get you by!! hahaha
I sure did Andy.
The starter turns over amazingly well..
It even has a different sound
Integrity, Money, Relevance
1amD1cker1@gmail.com
Today the croc started shifting hard..<br />I check the fluid and it's realllly low.<br /><br />Filled it with fluid and now it's still shifting hard. 1st gear shifts hard and when down shifting its hard as well.<br /><br />Looks like this thing maybe not be going to the excursion.
Blew a fuse for my speedo
I'm having a great f"n day
The transmission shifts hard to protect itself... You need to clear the code before it will stop.
The fuse for the speedo is important to the transmission, but it's also tied in with other things, so figure out why it blew.
philofab wrote:The transmission shifts hard to protect itself... You need to clear the code before it will stop.
Will clear the codes..Tomorrow..
How do I perform this again?
The fuse blew because I removed the center light with the door open to install the antenna.
Unhook the battery and turn the ignition for a few seconds. Should clear most soft codes. Did the check engine light come on?
philofab wrote:Unhook the battery and turn the ignition for a few seconds. Should clear most soft codes. Did the check engine light come on?
No check Engine Light....
Today I replace the #15 fuse that blew and i drove the Croc around the block and now I have smooth Shifts.
Im guessing the fuse for my speedo triggered a sensor that was not communicating with the transmission...
The Croc is back
economig
Post by economig »
Nice! I was trying to follow this, glad it worked out for you!
Jacob7672
Bronco Info: 93 Bronco, 400HP, C6, 2.5" coil 3" bypass 2" bump at each corner
Re: D1cker1 93 Build "The Badger"
Post by Jacob7672 »
D1cker1 wrote:Update....
I went to B500 this past wkd.. Spoke with the Secret Society Black Bronco guys
Rode In TCM GLX's bronco
Saw this Bronco that Ive always had a stiffy for....Image
Uploaded with ImageShack.us
So Yeah.. Additional changes will be made to my Build.... heres a secret tip
3.5-4" Over TTB
and the bronco won't be done by the august RUN :(
Spoke with BajaBronco.... Enough Said.
This is where my Bronco was parked the week leading to the 500 too. It was way in the back.
I like the SOLO bronco a lot too.
Quailhunter
Post by Quailhunter »
That's the same starter I put om my 408. Great choice, worth every extra cent. No fancy flat black wrinkle paint on mine. Nice!
Pre Baja carnage
Before we arrived to toms this happened.
This is the inside of my passenger door handle. The link broke so I can only open it from the outside
D1cker1 wrote:Pre Baja carnage
wtf is that?
glad I'm not the only one who was lost with that pic...
wtf is that?
lol
wtf is that?
lol
*edited*
Door handle?
