1995 Bronco - Slow lowbudget Gofast Project
I thought the rear wind deflector needed to be shaped like this to keep the back window clean...had ones similar on the Ramchargers I used to have
rushcanuck
Bronco Info: 1995 Bronco XLT, 5.8L, E4OD, Limited Slip Diff's, 340,000km's
Re: 1995 Bronco - Slow lowbudget Gofast Project
Post by rushcanuck »
thanks, yeah it feels good, the spoiler takes in air inside the spoiler threw the front and pushes it down the rear window much like that one on that jeep. just it has a lot more showy around the actual function
rushcanuck
took her for the first romp the other day
also ordered a 4" Procomp W/long-arms and rear add a leafs...should be here tmrw and hopefully installed by monday
rushcanuck
Gonna start with a strapped Procomp stage-II 4" lift with procomp shocks for now
rushcanuck
sum pics of the lift progress
Mojo
Post by Mojo »
Lots of good work. Don't forget to leave the swaybar off !!!
rushcanuck
well my part in the lift is done, gonna be sent off to get an alignment on monday
front end suspension
overall
Looking good. Have you taken it out? How's it do?
rushcanuck
no I havent yet, still needs an alignment which Im booked to have done monday morning. Cant wait tho!!!
Looking good man! It'll make for a great runner.
rushcanuck
Got the alignment done, costed over $900 because she needs all new U-joints, balljoints, tie rods, wheel bearings...pretty much everything at least its all perfect now
havent had a chance to actually take her out for a good high speed run yet... will do as soon as I fix the dashboard vibration
rushcanuck
Ok after my first test pre-run with ole penny Ive decided to take a more juristic route of plans
front:
-Auto-Fab Style (home made) Spring Bucket and shock towers
-2.5 Fox Remote Reservoir Shocks
Rear:
-Deaver springs
-longer shackles
-2.0 Fox Emulsion Shocks
and eventually a 2-link
Hopefully that'll be a rad setup, ready to rock and roll
rushcanuck
Well the truck went back on the hoist for the final tighten down of everything involved with the lift. However Im now having trouble deciding on my shock setup, Ive gotta set of F250 shock towers, and I was thinking of doing similar to what joxracing did, where I leave the stock coil tower, cut the main shock portion off and weld a plate there, then install the F250 tower in its place, therefor I should be able to use a double eyelet shock which opens up the possibilities.
Then I was Pricing out, for me a Blistein 5100 shock for the stock setup with a 4" lift came to $95 a shock. a 5150 of simular length came to approximately $130 a shock. and while a Fox Emulsion shock came to about $125 a shock and a 2.5" Remote reservoir shock was $170 per shock
if anyone could gimmie the advantages of each setup? least for the front, havent even touched base with the rear. Looking to start seriously moving it in the gofaster than stock direction
Full Droop
rushcanuck
Well took her out in sum sand today, I can say she did extremely well. my only complaint is the passenger side dash, and the truck needs to be re-geared after putting on the 35's!
I need to get a video of her out there but here's a photo
Also Im working on a drop center hood for it, will post pics when I have worthy progress
rushcanuck
here is the video
https://www.youtube.com/watch?v=qwYsOBtKcLs
and I took her out to do sum trail/rock crawling
