Uploaded with ImageShack.us
Yesterday a split formed about 2in long in this tubing.. It spewed Coolant as you can see in the picture
Agui-E7TE wrote:I mentioned this in the other thread but that could be a leak from one of the coolant hoses that go to the throttle body. If so, that's an easy fix. The reason that hose is there is so the coolant can flow through the throttle body to help warm up the throttle body in cold climates. I know you can bypass that on TPI camaro/firebird engines from the late 80's.. I would think its worth keeping on the Bronco though.
Anyone know a part # at oreillys or kragen?philofab wrote:That hose is a bypass that runs from the thermostat housing to the water pump.
I believe you are correct! Below is the Water Pump Bypass Hose...Agui-E7TE wrote:That's the coolant supply hose to the throttle body. It runs from the intake manifold to the bottom of the throttle body. That's a super easy fix.
