Big Bertha
300
Re: Big Bertha
Post by 300 »
May be easier finding a yoke, but isn't it just a matter of locating a CR catalog and finding a seal with the needed ID and OD? Sometimes those odd ball seals are more $$$ than they are worth.
Re: Big Bertha
300 wrote:May be easier finding a yoke, but isn't it just a matter of locating a CR catalog and finding a seal with the needed ID and OD? Sometimes those odd ball seals are more $$$ than they are worth.
Timken doesn't make a seal with the required id and od. It doesnt matter as the yoke actually rides in a needle bearing in the output shaft housing. Without the yoke riding on the bearing the tcase output shaft will probably break quickly. Bronco graveyard has what I need for $69.
big-d
Bronco Info: 1987 F150, 351W/418 Stroker, E4OD, F250 1356 W/fixed yokes, Sterling 10.25, D50 TTB 4" over
Re: Big Bertha
Post by big-d »
Did you end up lowering your pivot points or use the stock D50 locations?
I am starting a similar project, I am building a regular cab shortbed f150. It is going from a straight 6, C6, 2wd to a 418 stroker, E4OD, 1356 (fixed yoke F/R) Sterling 10.25 and some type of D50 based TTB.
I am trying to decide what route to go. I already have a D44 with the ends cut off ready to extend. Would I be better off extending a set of D50's and using the D50 pivots or using the 1/2 ton D44 housings and pivots with the D50 ends used to extend them?
Thanks,
Dustin
Re: Big Bertha
Hey Philo,
Oh grand Poobah... Got a question... have you seen and/or know where I can find a BW1435 rear driveshaft output yoke (fixed) that fits a 1350 u-joint? Anyone...? Bueller....?
Re: Big Bertha
1435 or 1356?
Re: Big Bertha
http://www.driveshaftsuperstore.com/
This place out of Phoenix claims they can build anything...
Re: Big Bertha
BajaF250 wrote:Hey Philo,
Sorry, typo... it's a BW 1345... pre 1356.
I'll check out the site you sent... thanks!
Re: Big Bertha
Scored another Dana 50 today. This one will be giving it's 4.11 center and hubs up to Bertha.
Thinking about sending the knuckles and beams out for plating.
Re: Big Bertha
Did you score the whole deal you thought you were gonna get or just some beams?
Re: Big Bertha
ChaseTruck754 wrote:Did you score the whole deal you thought you were gonna get or just some beams?
That chassis is separate from this. I have not figured how to get it here.
mxrider99
Bronco Info: Looking to get one!
Re: Big Bertha
Post by mxrider99 »
Any updates on this truck? Always loved it.
Re: Big Bertha
My business and personal life have been taking my time up so I have not done anything to it lately.
kylesgorter
Re: Big Bertha
Post by kylesgorter »
philo the pics arent working. i would love to see some pictures of this truck since it similar to mine but not dually
Re: Big Bertha
kylesgorter wrote:philo the pics arent working. i would love to see some pictures of this truck since it similar to mine but not dually
I shut down my old website and was not able to download the info there... I have to spend some time and rebuild the directories. Meant to do it a while ago but I've had my hands full with other stuff.
Re: Big Bertha
Some of the photos are back up.
kylesgorter
Re: Big Bertha
Awesome truck! Glad to see some pics
Re: Big Bertha
How bout a recent picture philo!
Re: Big Bertha
Updates?
Re: Big Bertha
tcm glx wrote:How bout a recent picture philo!
cs_drums wrote:Updates?
It's sitting next to my house under a tree covered in dirt and dust. I should probably pull it out and give it a good cleaning. Last time I started it, it ran really rough. I think the fuel pumps need changing again from it sitting so much. I'll probably clean it up, finish the welding of the bed cage, and paint everything so I can drive it around at the HDRA race here in a couple of months.
kylesgorter
Re: Big Bertha
Let's see some updates!
