Mufflers
Torta Runner
Mufflers
Hey guys I was thinking of getting a Flowmaster 10series or a 30 please I need to know what would be better thank you
Re: Mufflers
Moved to appropriate forum.
Re: Mufflers
Better in what way? Performance wise you will see no difference. Only diff will be the sound.
- Rednek Renegade
- Bronco Info: 1985 Bronco Xlt 5.8L 4V H.O. C6, NP2o8
Re: Mufflers
You could get a cherrybomb extreme which would be the same as a 10 series for half the price on ebay, i had one and it sounded bitchin. The 30 is going to be alot more quiet, if you want the best of both worlds get a super 44, its right between the two.
Project el cheap-o
- Squarehead
Re: Mufflers
I think I've got a 50-series, and it's relatively quiet, but with a deep rumble.
- magic carpet XLT
Re: Mufflers
i ran a flowmaster 40 delta for a long time and never realized what i was missing till i just swapped in a magnaflow 3" straight thru. sounds much better and even though its just as loud (maybe louder at WOT) it doesn't drone as bad on the freeway either, which is a big concern to me as i drive to wheel and with no OD 3k can get very loud after 3-4 hours.
monkei
Re: Mufflers
Anyone tried the Borla XR-1 Race muffs on a 302/351w?
gr8brnc
- Bronco Info: 96 Bronco, 535hp, lots of glass, coil overs coming soon
Re: Mufflers
I have a borla on my 351, not sure which one though. It sounds awesome!
Dust
Re: Mufflers
100% Agree! If you are making big numbers you are giving some away to that non Flow box.magic carpet XLT wrote:i ran a flowmaster 40 delta for a long time and never realized what i was missing till i just swapped in a magnaflow 3" straight thru. sounds much better and even though its just as loud (maybe louder at WOT) it doesn't drone as bad on the freeway either, which is a big concern to me as i drive to wheel and with no OD 3k can get very loud after 3-4 hours.
They sound like crap, which is just my opinion.
Re: Mufflers
Andy, do you know which model magnaflow you have?magic carpet XLT wrote:i ran a flowmaster 40 delta for a long time and never realized what i was missing till i just swapped in a magnaflow 3" straight thru. sounds much better and even though its just as loud (maybe louder at WOT) it doesn't drone as bad on the freeway either, which is a big concern to me as i drive to wheel and with no OD 3k can get very loud after 3-4 hours.
- bajascott
- My belly is my best friend
Re: Mufflers
i have a 3" straight through magna flo on my bronco, it sounds good when you are on it at high rpms...but it does get annoying on the freeway. headsets are worn on long runs down the highway.
i would love to change it out for something quieter
Re: Mufflers
I have a 2.5" MAgnaflow and full length exhaust pipe on mine. It sounds great at idle but sounds like a vacuum cleaner when it gets wound up. Now I wish I had gone 3".bajascott wrote:i have a 3" straight through magna flo on my bronco, it sounds good when you are on it at high rpms...but it does get annoying on the freeway. headsets are worn on long runs down the highway.
Scott, do you have a full exhaust on yours?
- bajascott
Re: Mufflers
no it dumps before the rear tire out the bedside....im sure full length would be alot nicer. i may do that when i get a job lol
Re: Mufflers
I have a 2.5 Magnaflow dumping right before the tire. It sounded way better before the short pipe after the muffler was added, but reduced the noise at highway speeds enough that it does not bother me. As an added plus it does not smell as much with the rear window down.SteveG wrote:I have a 2.5" MAgnaflow and full length exhaust pipe on mine. It sounds great at idle but sounds like a vacuum cleaner when it gets wound up. Now I wish I had gone 3".
- magic carpet XLT
Re: Mufflers
you can kinda see it tucked up under the skid, its just the 3" in/out 4" body straight thru. when you get the engine wound up a little bit it sounds absolutely wicked, it doesn't sound like a stock motor but it is. it just sounds uncorked.Nick wrote: Andy, do you know which model magnaflow you have?
my pops has a big magnaflow dual in/out on his big block truck and it has an awesome tone, perfect for a DD. also nice and quiet.
monkei
Re: Mufflers
"I have a borla on my 351, not sure which one though. It sounds awesome!"
I'm thinking about getting the Borla 40944 XR-1 Race muffler and going full length instead of side exit this time. Is yours maybe a pro-xs model? Is it center in/out or offset? Oval or round case? Single or dual in/out? All the way back or dumped short?
Re: Mufflers
Something I recommend and another I do not recommend.
After much breakage of the hangers and finally the muffler was cracked at the inlet all around the pipe.
I got a SS bellows from Summit. Should solve the breakage.
The muffler eqwas the shortest one we could locate at the time. Dont like it It is a Flowmaster Lenght is 13" or 16" pipe to pipe. It was suggested that a magnaflow would be quieter.
3" from the Y to the outlet.
Paul
Paul
- IMG_1267 (Large).JPG (93.83 KiB) Viewed 2241 times
Re: Mufflers
Here is what magnaflow did for me while they used my truck for some fixturing of cats and crossover pipes.
Corvette muffler in/out front. I wanted the muffler to exit in front of leaf springs and angle down at the body line and with the two cats this is the only way to make that happen. They nailed what I wanted and the tig welded SS looks bitchen. Sound isnt any difference really which I dont care one way or the other.
- muffw.jpg (281.02 KiB) Viewed 2207 times
Re: Mufflers
Very nice!
I used a stock Corvette muffler on an old 4 cylinder Ranger to do the same thing. It was such a nice, simple system. Great flow and great sound with none of that annoying 4 banger resonating. I was super specific when I had it installed and made sure it was super easy to remove, with nice flanges and it was tucked out of harms way. I sold the truck to a kid and a week later he had a hack cut it a part and cobble in a Flowmaster. I was so bummed!
- Rednek Renegade
Re: Mufflers
SteveG wrote:Very nice!
Got any pics? I have a 94 danger ranger with the 2.3L and it sounds like a old VW bug with the stock exhaust sys. Avoiding putting on a muffler cause I am afraid a Magnaflow will sound like a 4cyl. with a fart can. Any tips?
Project el cheap-o
