Baja Trip Aug .....What's on your to do list?
Races, meets, etc
Quailhunter
Post by Quailhunter »
Things I have to do: a. Reinforce bedside mounts. b. Mount fire extinguisher c. save for gas & tacos
Things I would like to do: a. Mount Motorola Maratrac behind Pass seat w/ hookup to intercom and headsets. b. Front skid plate.
Re: Baja Trip Aug .....What's on your to do list?
New front and rear bumpers, cage, link it, new rear end, wash it, new headlights, and new mirrors.
Install engine, lol. Oh and skids front and rear. Cage will have to wait.
323bronco
Post by 323bronco »
HAVE TO DO: Deavers,rear shock mount ,shackle kit,shocks,brake line,second battery,fire extinguisher mount,race radio,complete tune up,oil pressure guage,trans temp guage and carpet .
Broncodawg
Post by Broncodawg »
Tie cage into frame, add diagonals in the B pillar, move batteries to tub to make room for air cleaner box, mount gps. New rear shock setup from top of leafs through floor to new mounts off cage if time allows.
Before August Trip:
Wash, wax and teflon. Spray undercarriage with PAM..............
Before June Baja Trip:
Finish Cage
Dynamat interior (rear cargo area)
Reinstall seats
Install and fit all interior paneling
Fix A/C
Chk and fix Pinion bearing
Install Diff Guard
Was, wax and teflon!
tcm glx wrote:Before August Trip:
Show off!
Show off!
Its the June trip I am worried about hahahaha
philofab wrote:New front and rear bumpers, cage, link it, new rear end, wash it, new headlights, and new mirrors.
Wash it?
1) finish tuning the rear suspension
2) replace the ignition system (MSD)
3) clean, clean, clean!
BajaF250 wrote: Wash it?
No can do, the dirt is what holds it together.
Find a vehicle .....
and money :roll:
Agui-E7TE
Post by Agui-E7TE »
Get new lens for camera and some cheap UV filters to keep dust out (last lens lasted just over a year).
Save up for Tacos! :D
Hope the moon and starts align so that ill be able to make it... trucks in good shape though, gas and go.
guard
Post by guard »
I'd advocate stealing money for this trip...it's for 2 good causes! The vehicle part is easy once you solve the first issue...
AussieRod wrote:Find a vehicle .....
and money :roll:
flyinbronco
HuckMASTER
Post by flyinbronco »
Install vintage air conditioner.
Wait patiently & try & find some $ for room & tacos.
My truck list is waaaay too long still & I had a gracious offering for a seat & I'm taking it up.
Get suspension Installed in the front....
and Solo Rad Arms
Get a race radio and Baja HID Lights and a Light bar installed
If i find deavers and 5100's that will be on my rear.. If not it will just have 5100s in the rear
hope it happens.. lol
Integrity, Money, Relevance
1amD1cker1@gmail.com
BajaF250 wrote:1) finish tuning the rear suspension
2) Ignition system done,
3) washed inside, outside and underside!
1) gotta add some more spring and back out to the test track... almost there!
Spoke to soon.... going to do new axle bearings, as well as a water pump and t-stat housing. Also try to work a rear tire mount into the cage before then.
Finish Cage
Reinstall seats
Fix A/C
Install Diff Guard
