1995 Bronco - Slow lowbudget Gofast Project
rushcanuck
Bronco Info: 1995 Bronco XLT, 5.8L, E4OD, Limited Slip Diff's, 340,000km's
Post by rushcanuck »
This is my 1995 Ford Bronco I picked up last year for $1800CAN. 5.8L E4OD. this is my first car and Im 19 years old, doing everything myself with help from sum friends. Going to school next year to become a firefighter so I dont have a huge budget. After reading Joxracings build I felt inspired to start a thread of my own and build her up
SUSPENSION:
Im hoping to get sum help with sum idea of what things I should look into getting for suspension, I've got a budget of approximately $1000-1500 for the suspension. Im thinking 4" lift bucket coils (I dont know what brands to look at?), extended radius arms, I'd like to do C&T axle but looking at my price range Im probably gonna have to live with a drop bracket. for the rear Ive heard that deaver springs are the best so I'd be looking at a set of those, which part # would I be looking at for a deaver 4" lift spring. Ive gotta quad shock front end I dont know what brand of shocks I should go for gonna need them.
Front brakes are completely redone with new wheel bearings, ball joints are still good. Rear brakes are gonna be done before I start spending money on lifting it
ENGINE:
So far Ive rebuilt the motor, installed a COMP camshaft, new springs. ported heads In the process of installing a 4 core radiator, new water pump. possible plans for the future a K&N cold air intake. High output alternator
TRANSMISSION:
gonna flush it, and a Torque Converter lockup switch thats about it
DIFFERENTIALS:
Stock 3.55's, fluid was changed recently
TIRES:
I just purchased a set of BFG A/T's 33x12.5R15, so far Im loving them
BODY:
I built a pre-runner style pushbar for the stock bumper, I think it looks badass. a rear tube bumper. Tube tailgate with built in tire rack. Ive already repaired the small rust issues I had, and removed the shitty tire rack that been splitting my tailgate for 15 years
PICS:
Before work started:
new hubs/rotors/pads and a picture of the stock front suspension
bed lined the back
My goodys for the engine
the engine before rebuild
after cleaning the block, honing the cylinders
back together
after that I started building a pushbar
switch for the lights
body work
new tires
Wow looks good!
SuperSixAxis
Bronco Info: 1996 5.8, E4OD
Re: 1995 Bronco - Slow lowbudget Gofast Project
Post by SuperSixAxis »
Looking great! How does the motor run?
Pm Baja Scott, he is a top notch builder and might be able to offer you cut and turn options.
rushcanuck
thanks,
Motor ran well, a tad more torque than it had prior can get both 33's spinning even with the limited slip diff which it never was able to before. Engine does tick a bit, sound like just one lifter tho. took it into a shop and the mechanic says Its nothing to worry about, cant hear it while driving just a bit at an idle so my guess is a lifter just aint pumping up quite. I did overheat it slightly going up the mountain a few weeks ago but she still has got good wet/dry compression so Im not too worried about it, hence why Im dropping a new radiator and waterpump in her
I forgot to mention Ive also removed the vacuum pump and shortened the belt, not cats. MSD distributor cap and taylor plug wires
her in the shop today, tight fit. just topped up the fluid today and put a vacuum tester on it to make sure she doesnt leak fluid anywheres. will see in the morning.
old rad was completely plugged with mud, sand, crap, even leaked a bit
-rc
rushcanuck
all back together, completed the transmission flush this morning. for the first time ever it shifts smoothly, downshifts when it should. gonna go for a longer drive today to see if it corrects a few of the issues I was having. new cooling system is working awesome. got a few noises gotta look in too on. motor seems to have a little more valve train chatter than before the cooling system fix probably cause now I dont have a waterpump bearing thats fried...less background chatter!
rushcanuck wrote:all back together, completed the transmission flush this morning. for the first time ever it shifts smoothly, downshifts when it should. gonna go for a longer drive today to see if it corrects a few of the issues I was having. new cooling system is working awesome. got a few noises gotta look in too on. motor seems to have a little more valve train chatter than before the cooling system fix probably cause now I dont have a waterpump bearing thats fried...less background chatter!
I get a bit of background chatter when I'm driving, too, but I just tell her to STFU! :lol:
guard
Post by guard »
LoL, are we still talking about the bronco?
rushcanuck
hahahaha, yeah been there. If everything goes well today all I'll have to get done is new rear brakes then Im set to lift it. wanted to get all the maintenance done first. Im looking at the superrunner 5.5" lift from jeff's Bronco Graveyard. wondering it anyone has had any experience with it?
BRONCONUT
Bronco Info: '95 Eddie Bauer
Post by BRONCONUT »
Are you sure the tick isn't coming from the exhaust or egr? It might also be timing related.
rushcanuck
Might be the EGR, I originally thought it couldve been the exhaust so I put a new gasket in her and it didnt change....completely forgot about the EGR tho thanks. Im pretty sure its valve train but I'll check the EGR.
rushcanuck
Got her back running. still having the few transmission issues, now thinking of doing a ZF5 swap
Bombed around in a abandoned gravel pit the other day....sorry bout the shitty cell phone pic
got any pics of the rear spoiler? im kinda partial to those..they keep the rear end planted 9i know cuz i sorta have one) haha
rushcanuck
bajascott wrote:got any pics of the rear spoiler? im kinda partial to those..they keep the rear end planted 9i know cuz i sorta have one) haha
there you are sir! I have no idea who makes them. I believe they were meant for blowing air down the rear window to keep the dust off it. Im gonna trim a bit off for the 3rd taillight
Me and a buddy kinda run a recovery team for guys going up the mountain, had a bit of fun yesterday recovering this 1981 Chevy 3/4 ton pickup that lost a front U-joint, and had a tire go down and eventually flat, and broke off the bead. Due to the Bronco having a broken hub. we took a 1996 F150 - 4.9L up. it was a bit of a trip.
Fun day, it took us about 3 hours to drag there ass home threw sum pretty terrible terrain. then we helped them get there spare from the house (what good is a spare tire if you leave it at your house) and we ended up changing the tire for them too
Back to the project. took it 4x4ing out in a gravel pit and noticed a horrible grinding/thunk sounds from the LF hub. went out and got sum warn premiums
and another thing, probably gonna do a ZF5 swap by march, gonna have a donor truck hopefully by the end of the month if all goes well
Joxracing
Post by Joxracing »
I had to do a double take at that f-150, i thought it was my Nite. :D
How does that recovery business work? I was debating kinda starting one up here, because of all the dumbass kids who take there parents yukon's on the trail and get em stuck, and dont want the parents to find out.
rushcanuck
Re: 1995 Bronco - Snow-Runner Project
Well finally figured out my plans for the suspension
Procomp 4" lift with radius arms. FOA shocks. gonna make my own Coil buckets with shock towers and a cross beam over the engine. once I've got this setup I'll start to invest in a C/T'd front axle or attempt it with a jig Ive got from a friend who used to do it. Rear end will pretty much remain with whatever Procomp sends me. possibly blistien shocks
Also today we had a dump of snow up here, first of the year which is odd for this part of canada (usually it comes in november)
And lastnight, my buddy's girlfriend was driving his truck. roads were icy but the snow hadnt fallen yet. when she lost control and went off the highway rolled the truck acouple times going 95km/h. she walked away and is alright thankfully! wasnt the first time "shes easy" has shown off her underside, as my buddy had flopped her on its side once before, which is where she got the nickname "shes easy". She was a good truck, and still runs, fired her up in the lot.
R.I.P "She's Easy"
rushcanuck
Well now the transmission swap is finally happening, snow has dried up.
Ive got myself a 1992 F250 4x4 with a 351-ZF5 for $500. Plans are to take the 351 and E4OD outta the bronk, and the 351-ZF5 outta the F250 and put the F250 drivetrain into the bronk while I tweak sum issues Im having with the Bronks 351.
pulled out the bronks interior
F250 351 ZF5
sorry for the go-slow bronco stuff so far, Im making sure Ive gotta good reliable daily driver before I start going crazy with the go-fast stuff....hopefully if this all goes well I'll be doing the suspension in the fall
rc
rushcanuck
Pulled the broncos motor and trans
motor on its way out
didnt have a tall enough jack, so used the bobcat to lift the rear of the truck to drag the trans out... Oh yeah thats full droop in the rear!
and my goodbye to one of my biggest issues Ive had with this truck ever since I bought it
rushcanuck
Temporary Motor, 1992 351W
trans is dropped, should be putting it all back in the bronk pretty quick
rushcanuck
ZF5 swap is complete!!! frig yeah!
Congratulations, I'm sure that feels good
