Updates??
Nope.
Broke my leg back in Feb and have been on the mend and getting ideas, lots of them.
Plans and parts for the front axle are:
D44 TTB. Have 5.13 gears and a 4.09 up carrier. Waiting on JBG for install kit. Working on designs for Radius arm mounts, trans mount, and rad arms. Ideas for coil buckets floating around. Have Deaver 5.5 F150 coils for front, and a pair of 2.0 x 14" Fox res shocks that will mount to front of beam. Trying to get some hyd bumps, that will mount behind coil, and bump on the rad arms. Have limit straps. Just need to get going on things.
Engine will stay a 4.0L but will install an Auto to make driving easier for me. (Bad Knee and broke leg). Will install the turbo back on to new motor. Have HV oil pump, FMU and larger injectors to add, as well as intercooler. Dodge 2500 Brake master added for extra stop power.
Rear axle will retain the durango leaf pack. Drum Explorer 8.8 will go under, and stuffed with 5.13 gears, and mini spool. Spidertrax wheel adapters to change lug pattern, and get some width back to match front. Cantalever shock setup will be designed to use a pair of Fox 2.0 x 10 resi shocks. Limit straps and Sway bar will be added as well as HD diff cover.
Interior will get simple cage, and possibly fiberglass dash. Auto column to be added. Stereo deleted and an amp with Ipod to be used.
Exterior will get Newer rust free doors and fresh paint. Plan to flare fiberglass more to account for extra width of front and rear axle.
Merc project has been terminated. Will convert it to automatic to drive untill I get the bronco on the road.
Now I wish this cast would come off.....
4 weeks to go.
