Bronco Transmission/Transfer Case Cross Member
95_Bronco
Bronco Info: 95 Bronco Eddie Bauer
Post by 95_Bronco »
What did you guys do for your cross member instead of the massive skid plate cross member thing
SMT Racing: Co-Dog
Re: Bronco Transmission/Transfer Case Cross Member
95_Bronco wrote:What did you guys do for your cross member instead of the massive skid plate cross member thing
I still have a stock transmission cross member but I removed the skid plate thing since it was all bent up, hung to low, and generally useless.
95_Bronco
Post by 95_Bronco »
i think thats what im going to do...its got hung up a few times
SMT Racing: Co-Dog
gunit
Post by gunit »
I made a new one.
With the kind of hits I am getting I am glad it is still in place. Also it gives a place to mount the engine/tranny skid which does not take big hits but sure has some small ones. If you have a bent one I would recommend gettring a used and not bent replacement. Better to have the member take a hit than the transfer. The only issue I have is cleaning out the desert debris from it after each run
PW
damon1272
Post by damon1272 »
Tony had posted some great pics of Mark Keifer's version of a skip plate. Tied the front cross member into the skip plate.
PBR
Post by PBR »
where are those pics tony?
Ollie Penchansky
Penchansky Brothers Racing.
Made this one a few years back to work with the factory x-member. It's not the quickest to remove, but it takes less than ten minutes and it's very effective.
The pivot boxes tie in now too! but I've never fnished the front x-member.
This is a Ranger, but I've seen the same basic design applied to Broncos. Imagine a skid plate attached to the bottom of the triangle shaped brace that attaches to the radius arm pivots and passenger beam pivot.
magic carpet XLT
Post by magic carpet XLT »
Dezertbronco
Bronco Info: 1990 Bronco EB
Post by Dezertbronco »
magic carpet XLT wrote:...
Is that 1/4 cold rolled?
magic carpet XLT
i used 3/16" and it is all braced on the upside. it can take the full weight without flexing.
