Power Steering Pump Upgrades/Coolers
Re: Power Steering Pump Upgrades/Coolers
Transmission oil coolers out of Explorers work great as power steering coolers. They're the nice stacked type with 3/8 barbs. They also have nice flanges to mount with.
baja-chris
Post by baja-chris »
Power steering systems don't like the backpressure of stacked plate coolers. Instead, use a design that uses a tube with fins for the steering cooler. They can be found in the junk yard on some cars or purchased new. Some are just a simple U shape, some have several U like a serpentine tube with fins.
Tranmissions and engine oil pumps can push through the stacked plate (radiator style) coolers easily.
BajaDale
Post by BajaDale »
Get a power steering bracket and pump out of an e-series van. They bolt right up to your 302 - 351 and use a common saginaw pump!!
BajaDale wrote:Get a power steering bracket and pump out of an e-series van. They bolt right up to your 302 - 351 and use a common saginaw pump!!
Mmmm, I have one of those, with bolts and pulley waiting for me in CA :D
Having issues finding one of the 60-7272 pumps. Anyone get one recently? I saw on other forums that they discontinued them. Anyone have any info?
denhabr
Bronco Info: '96 XL 5.0L/E4OD "Autofab" Preunnner/Chase Truck by Utah's Ojive Industries & dp custom fab
Post by denhabr »
cs_drums wrote:Having issues finding one of the 60-7272 pumps. Anyone get one recently? I saw on other forums that they discontinued them. Anyone have any info?
Nope. I haven't found one either. Been looking myself for about 4 years now since I heard of this upgrade. I too would have loved to get a 60-7272 pump (or Napa #NSP 816795) to replace my whining stock Ford pump. Instead, I too thought about heading to my local Pick-n-Pull and find that pristine '96 5.0 Econoline Van and yank the Saginaw pump/bracket/pulley and do the swap...but just haven't gotten to it yet. :roll:
What I DID find is a performance replacement C2 pump built by AGR Performance for the Bronco...part #809156. About $136 from SummitRacing.com [http://www.summitracing.com/parts/agr-809156/] See photo below...
AGR Performance #809152 Ford CII (C2) OEM Rebuilt High Performance Pump.
AGR 809156 Ford CII PS Pump 1.jpg (12.25 KiB) Viewed 3031 times
...and here is their sales description for the #809156:
AGR Performance's high performance power steering pumps deliver outstanding power assistance without robbing valuable engine horsepower. Some features of these pumps include:
  • Exterior of casting receives a special finish
  • Custom porting to ensure strong fluid flow, while providing a long and cool life
  • Interior surfaces and bores are mechanically polished to a fine micron finish
  • Specially designed high-temperature, high-rpm seals
  • Bearings are custom-sized by a proprietary process for maximum performance at any rpm
  • Each pump is 100 percent Dyno-checked for pressure, response, and flow at varying rpm
  • Each pump receives a stringent fluorescent leak test
But then I did further searching tonight and found that AGR also builds what they call the "Super Pump"...a Saginaw-style pump that they list for (my) '96 Bronco as Part No. #867257. Yet I can only find a picture of their #847257 Super Pump which shows a Cardone-type steel adapter that looks like it allows their Super Pump to bolt to the aluminum P/S bracket on my '96. But the #847257 which they list for the 80-89 Bronco. :?:
AGR Performance #847257 Saginaw-style pump with some sort of adapter bracket?
AGR 847257.jpg (16.72 KiB) Viewed 3031 times
So, I wrote them an email tonight and asked them if the #867257 also has the metal bracket to adapt it to the OEM '96 P/S bracket. Will post the results when they respond.
Even though the A-1 Cardone 60-7272 is apparently no longer available...anywhere...there apparently are a few options still yet available. All of this can be found here at AGR's website: http://www.agrperformance.com/Off-Road- ... rmance.htm[/color]
Could this be the new part number 20-7272 found on RockAuto.com
denhabr
Post by denhabr »
robertcrav wrote:Could this be the new part number 20-7272 found on RockAuto.com
robertcrav,
Yes, that is the same one that comes up when I look for the 60-7272 'replacement' to the older Cardone version that was a Saginaw pump.
What is pictured is just a rebuilt Ford C2 pump...me thinks.
That looks like the stock one. Are there internal differences?
denhabr
Post by denhabr »
cs_drums wrote:That looks like the stock one. Are there internal differences?
Yes, I think that is just a rebuilt stock C2 pump.
What do you mean by "internal difference?" Internal differences between what? Which pump(s) are you referring to?
They also show the same model # with an "F" in it and it says it has a filter...not sure where that would go or if necessary...
Jbfab
Post by Jbfab »
I agree with using the e-series saginaw pump. I did this swap and can turn my wheel on flat ground with one finger. I know flat turning isnt the best for a pump but wanted to see the differance. I got everything from my local pick a part for about $25 lines and all.
retroblazer
Post by retroblazer »
I am a fan of extruded aluminum tubing for power steering coolers as they have excellent cooling properties and the big plus of being rock resistant. The one I use in the race car is 3" ID and 12" long. Lee was the pioneer of off road steering and Blazer's box was originally done by him , so that's why I started with him. I send my box and pump to them after every long race to be magna-fluxed and checked. Over kill, maybe, but it's no fun when you turn the wheel and nothing happens.
retroblazer
3" OD not ID
denhabr
Post by denhabr »
Regarding my post from 2 weeks ago today (June 10th)...
I spoke to 'Matt' at AGR Performance today about his #809156 Ford C2 rebuilt pump...and the rest of his Super Pump line of Saginaw style pumps.
The AGR #809156 version of the Ford C2 pump is modified internally with some porting and polishing and is designed to use synthetic P/S fluid. He said the 'whine' is pretty much gone with his rebuilt C2 pump...as long as you use synthetic P/S fluid and a good fluid cooler.
I also confirmed that both the #867257 "Super Pump" Saginaw P/S pump for the '90-'96 Broncos...and the #847257 "Super Pump" for the '80-'89 Broncos BOTHhave the cast iron horse collar bracket attached to the front of the Saginaw pump (see picture above...with the 847257 part number written in chalk on the casting.) This bracket allows these pumps to bolt up directly to the stock Ford C2 P/S bracket...albeit with some "slight trimming" of the aluminum casting (top and bottom) to permit the 'canned ham' reservoir of the Saginaw pump to fit properly! Matt informed me that the shaft is also turned down to accept the original pulley from the C2 pump!
He referred me to this .pdf that shows what some of the trimming looks like in order to fit the canned ham housing into the bracket (http://www.agrperformance.com/AGR-Insta ... nstall.pdf). A few of those pictures also appear below...
Matt also mentioned that there is another option available to these two Super Pumps that further enhance their longevity. He said if you add the letter "T" to the end of the part number (when ordering), you get a stronger pump shaft, thrust bearings, special seals, and some other changes that really turn the pump into a special heavy duty model. Please call them for details.
So now...I'm not sure WHAT I am going to do on my '96 5.0. Maybe just the rebuilt #809156 C2 pump with a H/D cooler and Redline full synthetic P/S fluid...and call it a day...?
This is what the final trimmed bracket and pump assembly looks like...on an F-250 Super/Duty...
2013-06-24 17.32.24.jpg (30.55 KiB) Viewed 2856 times
2013-06-24 17.32.59.jpg (53.04 KiB) Viewed 2856 times
2013-06-24 17.33.11.jpg (37.21 KiB) Viewed 2856 times
2013-06-24 17.32.47.jpg (43.12 KiB) Viewed 2856 times
Seabass
Bronco Info: 96 bronco
Post by Seabass »
Denhabr did you get any prices with your email? Cost is pretty much the deciding factor for all my projects. :D
Seabass
Post by Seabass »
Is that the same saginaw pump casting that would come on athe e-series and the adapter is only so you don't have to buy a new bracket?
Same casting but a different shaft and reworked internally in addition to the horseshoe adapter.
The canned ham res is not much of an upgrade if your system has a cooler, filter, or other oil volume increasing modification.
The factory high pressure hose will work with if you have the correct Sag fitting. There are four, two standard and two metric. The only mod I had to do was lengthen the pressure sensor harness.
Seabass
Post by Seabass »
So in theory their pump would work with a van bracket and you could skip the horse shoe chingas?
The shaft will be too long then.
