I-beam Pivot Brakets
Hey guys, i was wondering if i need to get a stock passenger beam bracket. for when i remove my rancho 4" lift for my C&T's?
here's a few pics.
whatdyisit
Re: I-beam Pivot Brakets
Post by whatdyisit »
You should be able to cut off the bottom "ear" of the bracket and use the upper bolt location. Yikes cut his lift brackets to work with stock pivot location. Maybe he has some pics for you.
Thanks.... Not what i asked, as im trying to sell the kit as a whole.. with further inspection it looks as if i need one.
whatdyisit
Didn't know you were trying to sell the kit. Ya you'll need one.
Bondobob
Post by Bondobob »
Ok not I-beam but are the factory ttb beam connection points GTG with my extended radius arms and cut and turn beams or should I plate or gusset them to add some more strength and rigidity while I have everything apart???
87 cross1.JPG (273.99 KiB) Viewed 1560 times
Elwood Blues -1980
Andy, if you cant find one, I have one. If you pay the postage, it free to you.
Hey Bob, I just bolted mine up. I've heard, if anything, drill out the ttb mount hole and weld washer it.
Bondobob wrote:Ok not I-beam but are the factory ttb beam connection points GTG with my extended radius arms and cut and turn beams or should I plate or gusset them to add some more strength and rigidity while I have everything apart???
They'll last quite a long time as they are. I'm pretty sure the same bracket pictured lasted about 15 years on Ollie's old Bronco. I think it cracked around the frame mounting bolts and not the pivot hole. I'm lazy. I would just bolt it up, but it certainly wouldn't hurt to gusset the bracket and pivot hole.
Dale (bajanorth) cracked his after a couple of years. He added weld washers and a tube from the outer part of the bracket to the bottom of the frame rail/coil bucket.
AusBroncodoc wrote:Andy, if you cant find one, I have one. If you pay the postage, it free to you.
What do you think Postage would be to 92587 Canyon Lake, Ca
mesquito_creek
Bronco Info: No Bronco 92 F150 4x... Pretty close?
Post by mesquito_creek »
Alot cheaper than the 150 bucks most places like AutoFab and the rest will charge you to pull a set off a salvage and ship...
I let me last one go for $25. Just out of them right now or I'd charge you the same. Shipping will probably be reasonable if you're not in a major hurry & let it take the boat!
Ì'm guessing $20 - 25 airmail. If you want it, I pull it this weekend and take it to the Post Office monday for a firm price.
Sounds good!
This is BajaDale's fix for cracking.
I will do the same thing on my F100.
Any pics of the Passenger Beam Bracket Modified??.
Dont need to, its completely different.
hobbyturnedobsession wrote:Dont need to, its completely different.
would you have to put a weld washer on it for reinsurance!?.
The bolt goes through the cross member on that side which is thinker than the brackets. A weld washer on the bracket wouldn't hurt but I doubt it's needed.
Bondobob
Post by Bondobob »
I went a head and did the passenger side this way.
Elwood Blues -1980
