Philofab's shop Ranger
Re: Philofab's shop Ranger
James came yesterday and we sorted out the paperwork so I've actually had a chance to drive it a little bit. It has an odd issue with the fuel injection.
It can be hard to start occasionally. Leaving the key on for 3-6 seconds before cranking works best. With the Key on engine off the fuel pump never shuts off. From the sound of the pump it may be loosing prime when off. I have yet to start checking the wiring / fuel pump relay / ecm. No check engine light, light does illuminate on bulb check.
I also removed the 2" wheel spacers and put a nut on the pivot bolt. Looks like the ranger cross member is much tighter than a full size so I will need to trim it for equal length clearance. Noticed the truck has a non gear reduction starter... probably swap that out for a little weight savings.
E-brake does not work due to cage being in way of foot lever and explorer rear swap. I think I'm going to install a heavy equipment / fork lift style brake lever between the seats. Old cage needs cut out, not welded 360, horrible weld quality, and a seem in between the a-pillars on top hoop. Someone has cut the frame attachment bars.. maybe to quiet it down? Not sure.
I think all the b-pillars on the new cage will be behind the cab for extra room.
- johncharlesb
The intermittent nature sounds like a coil to me. Does it start well cold? A fuel pressure check would be in order too.philofab wrote:It can be hard to start occasionally. Leaving the key on for 3-6 seconds before cranking works best. With the Key on engine off the fuel pump never shuts off. From the sound of the pump it may be loosing prime when off. I have yet to start checking the wiring / fuel pump relay / ecm. No check engine light, light does illuminate on bulb check.
I'm pretty sure it's a fuel issue and not one of the coil packs. It's starts the same regardless if it's cold/warm or been sitting/just run.johncharlesb wrote:The intermittent nature sounds like a coil to me. Does it start well cold? A fuel pressure check would be in order too.philofab wrote:It can be hard to start occasionally. Leaving the key on for 3-6 seconds before cranking works best. With the Key on engine off the fuel pump never shuts off. From the sound of the pump it may be loosing prime when off. I have yet to start checking the wiring / fuel pump relay / ecm. No check engine light, light does illuminate on bulb check.
If the problem goes away when I swap the emissions coil pack to firing order I will know it's a coil pack. As an added plus I will have a redundant ignition minus the crank trigger.
Fuel pump is staying on with ignition regardless if there is a fuel pump relay plugged in....
Inertia switch was popped. So now I just need to find where they spliced power into the circuit.
- SuperSixAxis
- Bronco Info: 1996 5.8, E4OD
SWEET!
Found the splice near C101. It's amazing the fuel pump didn't burn the 22/24 gauge wire up. Now that it's fixed it is starting better. I need to install a bypass switch on the inertia for racing. I've never managed to pop the one on my Bronco but you never know.
The ranger I had used to have problems with the inertia switch.
Truck is running a lot better now. Went to the junk yard today to find a tail gate, passenger inside door handle, and some other bits and pieces. Yard is empty so Monday or Tuesday I'll go over to the staging yard and pick the stuff I need before the tweakers destroy it.
Messed around with the door chime circuits a little... someone in the past removed the module. I'll need one of those now too.
I also located a complete 2.5 engine to use for this thing if I don't swap another engine in it.
I tripped the fuel pump shut off/ inertia switch in my ranger when running it at ROR...but that probably had something to do with landing on the front bumper.
I figure an override toggle on the dash will cure that problem, and still leave the system intact for street use.Wood wrote:I tripped the fuel pump shut off/ inertia switch in my ranger when running it at ROR...but that probably had something to do with landing on the front bumper.
Woohoo, got a door chime module from an Explorer... now I won't leave my headlights on!
Got a sweet tailgate for $5.43 at pick apart today...
- ImageUploadedByTapatalk1324151580.757199.jpg (80.86 KiB) Viewed 1022 times
Oh, so far I'm into this truck $775 minus $45 I made from the wheel spacers.
Current total is now $735.43.
I'll dig up the registration cost too...
I think you should base the color scheme off the tailgate.
Haha, full on retro?
- Joxracing
agree with steveG!
Went to drive the ranger to California yesterday and only made it 80 miles or so. Transmission couldn't handle the power of the 2.3!!!
- ImageUploadedByTapatalk1324830046.173402.jpg (80.39 KiB) Viewed 964 times
No worries, time for an LS motor?
