Got a ride to Barstow, then caught a ride from Tony (TCM GLX) to Bakersfield where I met James' dad to pick the ranger up.
Driving home on the 58 with a speedo that's way off. Need to fix that.
Luckily the truck had a full tank of gas when I picked it up... almost made it all the way home. Apparently the fuel gauge isn't the most accurate... it was above half a tank in Barstow and then quickly fell. Had to stop at Slim's gas station in Essex to get $20 worth to make it home. I'm lucky that station is there... The truck started sputtering about 5 miles before it and I was able to nurse it to the pump.
The next day at the shop I started cleaning it out and inspecting it.
Someone has put a roll cage in it that I will need to cut out and replace. Also, the rear shackle hangars are welded to the frame so I will need to fix that and flip the shackle. Red interior... Bleh. Wheel spacers on the front. Bleh.
First order of business is check maintenance stuff, then build a set of beams for the front to get rid of the spacers. Tires have flat spots from sitting so I may swap a set of 32" short course tires onto it.
Truck is a 2.3L five speed with an 8.8 disc brake Explorer rear. 4.56 gears. Support cover. Radius arms have heims... not sure who made them.
