96 chase bronco
cuz_im_CR
Bronco Info: 96 xlt stock
Re: 96 chase bronco
Post by cuz_im_CR »
ok so i think the rearend is bent. it currently has yukon 456 gears and a detroit trutrac in it i think. i was thinking about just pulling the rearend and sending it to currie to have them widen it and put the 1541 flanges on the end to eliminate the c-clip. id also be upgrading to 1/4 axle tubes and explorer disc brakes.
do you think its worth it to just spend alittle money on a 8.8 rather than 3-4k on a nice 9''? i dont ever plan to link this thing as i have a nice linked ranger now. this will be for family fun trips and mild prerunning.
currie wants 1500$ for all that and i was curious if you all thought it was worth it
Re: 96 chase bronco
cuz_im_CR wrote:ok so i think the rearend is bent. it currently has yukon 456 gears and a detroit trutrac in it i think. i was thinking about just pulling the rearend and sending it to currie to have them widen it and put the 1541 flanges on the end to eliminate the c-clip. id also be upgrading to 1/4 axle tubes and explorer disc brakes.
I think the 8.8 is a great unit.... $1500 is alot less than you would spend on a 9" Once you start looking at 3rd members, etc etc etc
Re: 96 chase bronco
Dump the 8.8 & replace with a corporate 14. Buy the 5x5.5 lug pattern hubs, whatever gear ratio you want and a locker and sell the 8.8 to offset the cost.
Corp 14's have 35 spline axles, are strong as hell and dirt cheap. The slight downside is unsprung weight.
You can buy and build a complete corp 14 for under $1500. Under $1k if you shop around a bit...
only1mikey
Bronco Info: 84 Bronco
Re: 96 chase bronco
Post by only1mikey »
Chris, if you decide to go 9" I'd be interested in those gears and locker.
Mike
Re: 96 chase bronco
Post some pics of the rear set up..
cuz_im_CR
Re: 96 chase bronco
Post by cuz_im_CR »
into the shop she goes. had a overheating issue this past weekend in lecurne. hope i didnt loose a head gasket. it got hot when the wire for the electric fan broke and now everytime i drive it i can only put a couple miles on it before it gets hot again.
as for the rest im putting a cage in it, 3.0 bypasses in the rear, rear bench seat, harnesses, 7" gps, 4 place intercom, winters shifter, new front and rear glass and some other odds and ends that i think of.
should be fun once its done.
Re: 96 chase bronco
Sweet! If I were you go with Currie. I've done alot of research and talked to some good people filled with knowledge and they told me that the currie setup is perfect for a prerunner application. Remember if you want a rear truss, although not the crasiest, you can have them built to be able to unbolt the rear panel, but with .25 axle tubes you shouldn't need it.
cuz_im_CR
Re: 96 chase bronco
Post by cuz_im_CR »
some cage progress. still have a ton more to go.
only1mikey
Re: 96 chase bronco
Nice Chris! You heading out to Barstow to pick up trash in a few weeks?
Mike
cuz_im_CR
Re: 96 chase bronco
Post by cuz_im_CR »
we sure are. i dont think ill have to bronco there but ill be in my superduty... it can carry more trash anyways....
cuz_im_CR
Re: 96 chase bronco
Post by cuz_im_CR »
doin the best i can to get this thing finished up but im trying not to half ass it so it is taking forever. not to mention to work on it i have to drive 120 miles each way. here is a couple more pictures. ill update this thread with pictures (camera phone only...sorry) everytime i make some progress. here is what i did on thursday....
-cut out both factory bedsides.
-cut out most of the inner fenders so i can mount 3.0x16 3 tube bypasses
-pulled apart my deaver f53s to bump the suspension
-made the plates for the lower shock mounts
bronco rear suspension bumped and rear fenders cut out. still need to finish the fenders. it was just a quick plasma cut job
inner fender cut out for the shocks.
tube tucked next to the dash
SuperSixAxis
Bronco Info: 1996 5.8, E4OD
Re: 96 chase bronco
Post by SuperSixAxis »
Did you ever figure out the motor issue? Was the head gasket bad?
only1mikey
Re: 96 chase bronco
Looks good. I like the "don't rush it but don't let it take too long" mentality words I try and live by hahaha.
Keep it up.
Mike
cuz_im_CR
Re: 96 chase bronco
Post by cuz_im_CR »
whelp just went a bought 5 wheels and tires for the bronco.... 35x12.50x17 general race tires and 17" forged alcoas. super happy with them. now i gotta drive out to the desert and work on it tonight and tomorrow. i want to have it done for new years.
Re: 96 chase bronco
NICE!!!! I'm picking up some of those from the team I pit for. They are last years ProTruck wheels. I have heard they have odd offset...have you test fit them?
cuz_im_CR
Re: 96 chase bronco
Post by cuz_im_CR »
the rims seem to fit pretty good in the rear. i dont have 5/8 studs yet so i can bolt them up. more pictures from this weekend
Re: 96 chase bronco
I really like the rear seat.. Who makes It..
Noticed your selling your front fenders..I'll know if want them if i find some coilovers
Integrity, Money, Relevance
1amD1cker1@gmail.com
Re: 96 chase bronco
Looks good Guys!
Re: 96 chase bronco
Cage is looking good!
SuperSixAxis
Re: 96 chase bronco
Looks like a Twisted Stitch....
