Hello,
My name is Keri and I was brought here by 2 folks, Big Bastard and bajascott. I live in Vancouver, WA and work as an engineer in Portland, OR. I bought my truck last year and fall in love with it everyday. I bought it pretty much the way it sits but I did put a rear end under it. I used to daily drive it until I bought a Porsche in May.
Specs:
2002, 2wd, 5spd with 4.0L swap. It originally was 2wd with a 2.3L. The kid that built it swapped in a 4.0L from another 2002 Ranger that was 4x4 and left the tranny mated to it. So I have a tcase just hanging out under there. He did not swap over any wiring so I can't get low range in the rear end unless I were to do manual linkage.
Front:
Camburg 5.5" kit
Radflo 2.0's
Fox 2.0 bump stops
Gusseted lower arms
4" Hanneman fiberglass
Rear:
Deaver f23 leaf pack
Fox 14" 2.5's
Dixon Bros Bedcage
Kartek drop hangers
Custom 6" Shackles
Pulled bedsides
8.8 rear end from an Explorer - disc brakes, 4.56 gears, limited slip, trussed
Engine:
2002 4.0 SOHC
AutoFab solid motor and tranny mounts
Interier:
Full CLEAN cab cage - 1.75" x .120 DOM and 1.5" x .120 DOM
Full dash with AC and defrost
Crow 4pt harnesses
Pioneer head unit with 10" sub
CB radio with 102" whip antenna
Misc:
DDM 35w HID's
I have two full size BFG all terrain spares and a customized fabtech tire spinner in the bed
Longacre 17" panoramic mirror
Custom fire extinguisher mount
Loooong to do list!
2002 Ranger Prerunner in Vancouver, WA
trophygirl
- Bronco Info: 2002 Ford Ranger Prerunner
trophygirl
Re: 2002 Ranger Prerunner in Vancouver, WA
The way it was...
I stripped and painted the bed cage while the shocks got rebuilt
there's bits of trucker girl flair around
All mounted up with custom reservoir clamps
New rear end
Custom fire extinguisher mount, yes it has ladies too
New rear end
trophygirl
Cage
- 1280171163668imagejpeg_2.jpg (53.04 KiB) Viewed 985 times
- IMG_1615.jpg (74.26 KiB) Viewed 985 times
Not a bad looking Rig! Welcome to the site!
