85 bronco racin the 1450 class in southern california
FATsloppyBRONCOS
- Bronco Info: 85 bronco, 351 built, c6 trans. 2wd ibeam front, 24" travel. 4link rear, 27" travel.
about 6 months of fab and testing left before i start racing.
- 040.jpg (43.16 KiB) Viewed 4923 times
- 038.jpg (53.09 KiB) Viewed 4923 times
- 039.jpg (54.85 KiB) Viewed 4923 times
- 037.jpg (52.04 KiB) Viewed 4923 times
FATsloppyBRONCOS
more pics
- 053.jpg (57.36 KiB) Viewed 4884 times
- 052.jpg (30.53 KiB) Viewed 4884 times
- 051.jpg (51.8 KiB) Viewed 4884 times
- 041.jpg (59.38 KiB) Viewed 4884 times
FATsloppyBRONCOS
...and more pics
i would appreciate any advice i can get, this is my first build.
- 056.jpg (53.03 KiB) Viewed 4884 times
- 055.jpg (64.24 KiB) Viewed 4884 times
- 054.jpg (45.55 KiB) Viewed 4884 times
Re: 85 bronco racin the 1450 class in southern california
What part of so Cal do you live? I raced my 1996 Bronco in the 1450 class last year in the M.O.R.E. ORAF 500. Maybe I'll be seeing you out there. Do you plan on racing M.O.R.E.?
FATsloppyBRONCOS
i ride shotgun in my buddy's ranger 1465. he's runnin mdr. so i wanna go racin with him first, but definately wanna check out m.o.r.e ive heard a lot of good stuff. im live in temecula, but rite now im stuck workin in oklahoma for the next 5 weeks
Well good luck and keep posting!
BLACKMARKETBRYAN
- Bronco Info: its blue has 450hp ,was built with 3 grand and your mom is jealous
What are your plans for strengthing that area of the frame you notched out ?
proud supporter of kaveman motorsports .
p.s .
I HAVE A FAN CLUB OF HATERS
p.s .
- Brett Frederickson
I would backhalf your bronco at this point theres no reason to leave the frame.BLACKMARKETBRYAN wrote:What are your plans for strengthing that area of the frame you notched out ?
baja-chris wrote:
Just add $40k and you could have a nice $25k bronco!
I'm a little concerned about your c-notch in your frame as well. When building a race vehicle "over kill" is just about right.BLACKMARKETBRYAN wrote:What are your plans for strengthing that area of the frame you notched out ?
"I only drive as fast as I can see!"........-Jack Burtain
FATsloppyBRONCOS
im not done with the notch. thats getting plated with 1/4" and boxed in. just ran out of time and wanted to post up some pics. im workin out in oklahoma so i cant finish her up for another month. gotta plate the notch, bleed the brakes, mount the belts, put oil in the bypasses and mount em, bungi the limit straps, put a strap under the drive line, weld up and install the new exhaust and finish up some welding. should be about a weeks work, when i get home, and ill get to do te first test drive. thanks for the advice, i appreciate it
FATsloppyBRONCOS
havnt been on for way too long and im stuck workin out of town like always. this economy sucks a fat one. so as of late ive been working on rebuilding the front suspension. i got an equal length beam kit from jeff over at giant, got those finished up and installed and im almost done with the radius arms. gonna rebuild the engine cage next and lower the ride height a few inches. ill post pics this weekend when i get home.
- economig
Sounds cool, i'd like to see more of the front. Thanks for posting & good luck!FATsloppyBRONCOS wrote:havnt been on for way too long and im stuck workin out of town like always. this economy sucks a fat one. so as of late ive been working on rebuilding the front suspension. i got an equal length beam kit from jeff over at giant, got those finished up and installed and im almost done with the radius arms. gonna rebuild the engine cage next and lower the ride height a few inches. ill post pics this weekend when i get home.
Great to see Bronco's being built to race....... Are you plannning on running the MORE Series?
