fiber glass fenders on a stock bronco
jimmyd
tech thread for glass fenders?
Post by jimmyd »
is there start to finish tech thread for doing front fiberglass fenders? i am about to start mine (going to go with the skin the outer from the inner method). wanted to see if someone has done a write up.
Re: tech thread for glass fenders?
Hey Jimmy,
I didnt do a write up, but did do some picture whoring in my thread from when I did this to my Bronco. Slow, long and tedious process, I would suggest picking up two spot weld removers from HF as well as some cutting discs.
damon1272
Post by damon1272 »
Go to the Autofab web site. John has a whole write up on it.
jimmyd
Post by jimmyd »
yeah thats what i was planning on doing. why 2? do they break? and i'll check out the autofab writeup.
jimmyd wrote:yeah thats what i was planning on doing. why 2? do they break? and i'll check out the autofab writeup.
The cutting blade gets worn, there are so many damn spot welds it is nuts! I went through 1 for each fender.
cwrisley
Post by cwrisley »
Im also interested in a write up on this, but I will be building my own supports. Whats a common or good size tubing? 1 inch? Any pics would be helpfull. I checked out AutoFab's site, they have a bunch of old black and white small pics. Kinda hard to get a good idea of what they recommend.
@cwriz
1" x .095 would work well for these. You can even go .065" if you want to keep it lighter.
ChaseTruck754 wrote:1" x .095 would work well for these. You can even go .065" if you want to keep it lighter.
There are some issues with the lighter tubing fatigue cracking, I would recommend you stay with the .095".
But, I'm also using 1" on the top bar and ¾" for the rest of the structure.
cwrisley
Post by cwrisley »
Im gonna hold off on building traditional supports and wait until my shock towers are in and build something similar to Mikes setup....
Too cool, and looks super clean.
@cwriz
That's a nice set up there Chris. Any more pics of that ride?
Oh yeah, thanks for the front bumper. Steve dropped it off at my house.
cwrisley
Post by cwrisley »
http://www.gofastbroncos.com/forum/view ... f=33&t=759
Youre welcome for the bumper, glad it will get used instead of rotting in my side yard!
@cwriz
frank!
Bronco Info: 1989 stock bronco
Post by frank! »
has anyone mounted fiber glass fenders on a stock bronco.... and has pictures of it they wouldnt mind sharing....want to see how it looksim thinking of purchasing some... thanks
Re: fiber glass fenders on a stock bronco
Sounds like he is asking for pics rather than a how to
economig
Post by economig »
start at PAGE 6 of "Tony's 93 Bronco" in the rides section. lots of great pics, mixed with how-to IMO
Andy (silverslk) had his Bronco on 35s with stock glass on it and a leveling coil. Looks great!!
Build thread:
http://www.gofastbroncos.com/forum/view ... 4&start=60
scraptor
How did you hang your fenders ? Help a freezing Canadian plz
Post by scraptor »
If you could all be so kind as to post some pictures of your glass fender mountings, it would help me decide how to do mine. Thanks
Links would help too. Image
This fender mount keeps coming loose after a mile or so, says he can t run that fast.
Re: How did you hang your fenders ? Help a freezing Canadian plz
There are a few ways to do it. One is to skin the outer fenders of the originals from the inners. Look at Tony's (TCM GLX) build. He skinned them and Steve (Chasetruck754) welded supports in. Thats probably the easiest way to do it.
