Carl's 86 EB Build
Re: Carl's 86 EB Build
That is looking real good Carl! Several of us will be out at the MORE race, we should hook up out there.
The main shock might also be a bit short because of its mounting location on your radius arm. On the stock radius arm, I believe it mounts a little higher, a bit taller than the coil mouint is, look at this picture:
*** Also, side note, those boots melt onto the shocks when pushed hard.
fixxor
Bronco Info: 03 Ranger 4x4 no more bronco :(
Post by fixxor »
Yeah I dont know where ill be out there but we will see. Hmm, maybe I should just make my own mount on top of the radius arm. Thanks.
fixxor wrote:Hmm, maybe I should just make my own mount on top of the radius arm. Thanks.
I would definitely look into it. While you're at it, I would check the front mount as well.
fixxor
Post by fixxor »
front seemed fine, I had to push it down from where i had it jacked up to get it into the bucket. Then the back one needed about an 1 1/2 inch to be good.
I meant at full compression. I would make sure the shocks are almost completely collapsed (leave some room for chassis flex) when the suspension is at full compression. That way you know you're using all available wheel/shock travel.
fixxor
Post by fixxor »
Oh. I made an extension for the bump stop so I probably have some play room with the shock on compression but the limiting factor was my tire. Was hitting the inside lip of the fender, I plan on cutting it out some so I can go further. Maybe glass in the future.
fixxor
Post by fixxor »
It's done! Well, for now, for a bit. Finished it up this weekend but sadly not for the race. Made the main shock tab higher and put some limit straps on.
Notice in the last picture how my front tires stick out almost 2 inches past the fender. I have grown to hate this, flings up rocks and crap and chips the paint so whenever I do get it painted im not gonna be happy. Anyone have any recommendations on wheels that fit better inside the fender? Would want to go to a 16" for better tire selection.
Go back to the factory wheels, 15x7 or 15x7.5 will solve 99 percent of that. Those wheels look wide, and with a deep offset pushing them out.
fixxor
Post by fixxor »
Will 35x12.50x15 still fit on the 15x7?
Yup
BajaDale
Post by BajaDale »
fixxor wrote:Will 35x12.50x15 still fit on the 15x7?
Hell ya! We ran 15x7's on the ProTrucks for a while! 8-)
KBL
Bronco Info: Working on a '73 F-100 with a TTB conversion
Post by KBL »
Your wheel bearings, knuckle ball joints, and tie rods will thank you for going to different wheels, too.
www.off-roadweb.com
fixxor
Post by fixxor »
Alright. Little update. Found some factory wheels sitting in a bronco at the junkyard and couldn't pass them up. Glad I didn't I love they way it looks now.
Also saw it had some warn hubs on it. So I popped those off and it was a 92+ bronco. Looks like one side is shot is there a rebuild kit or I need a whole new unit? I'm not sure if these will work on mine but they do look like they would I just need to be sure.
fixxor
Post by fixxor »
Got it back from paint. She looks pretty now...
Looks great!
Looks awesome! Who painted it?
fixxor
Post by fixxor »
Some guy my coworker knew. Just does this on the side and more into just painting bumpers and stuff. But he did an excellent job.
Your not kidding it looks awesome!!!!!!!! I've been thinking a maaco job may do the trick.
Hawt damn she looks great!!!
Brad12
Bronco Info: STOLEN 1994 XLT, 6 in. Superlift, ext. RAs, 35X12.5 R15, TTB, 8.8, 351, 3.55, K&N
Post by Brad12 »
that looks great! Is your rear tire pushed forward a bit? or is that just the picture?
USA
