Custom Stainless Steel Y-Pipe for Mass-Air - Any Interest?
- sydude
Without any success, I've been looking for a better off-the-shelf alternative for the undersized plastic 'Y' pipe that everyone seems to be using to connect our single mass-air meters to our twin-blade throttle bodies, as I believe that the current 'Y' pipe must be restrictive - it's just waaay smaller in diameter than my 80mm mass-air meter or my twin 56mm throttle body.
So I drew up a sketch of what I needed and sent it to 4 of the bigger custom stainless exhaust/header component makers, asking for quotes. The lowest price I received back was $95 for one unit, which I'm taking them up on even if no one else wants one, but I've also asked what kind of volume discount we could get.
If you have any interest in buying a unit at $95 (potentially less), please reply here. I'm also posting this on FSB, so maybe there will be decent interest.
Here's the draft sketch and the comments I submitted for the quote - this is not final and can be tweaked, so give comments if I can make any improvements:
- Screen shot 2011-03-01 at 3.20.41 PM.png (85.99 KiB) Viewed 2728 times
- sydude
Re: Custom Stainless Steel Y-Pipe for Mass-Air - Any Interest?
The image above seems like it was too big, so here's a smaller version.
- Screen shot 2011-03-01 2.png (81.9 KiB) Viewed 2725 times
monkei
I'm looking to make or get one made that has a 90mm MAF side and 61mm TB side with 15/16" gap
- sydude
The same guy could do both I guess. What do you think about the pricing?
Also, I'm assuming you have a BBK twin-61mm throttle body - I have the twin-56mm BBK and took a rough guess with the .5" spacing between the tubes. So your number of 1" is probably the right one for my throttle body as well.
monkei
Seems like a fair price for a custom fabbed stainless TIG welded piece, I'd be willing to pay it.
I'm whipping up a model/drawing of what I'm hoping for...
I would be interested in having one made.
- sydude
He came back with quantity order pricing of $84 for 5 units and $79 for 10. All pricing so far is un-negotiated. If you want to know who the vendor is, PM me, I don't want to post it publicly.
monkei
Drawing based on measuring my 61mm BBK with calpers.
- solid model also available
- ypipe.JPG (216.8 KiB) Viewed 2660 times
Dont know where youre at on these but Im for sure interested.I have the 61mm x 2 BBK as well .And have a Paxton supercharger going on so this would help flow.
monkei
Yogib, what size MAF are you using?
Sydude, I'd definitely be interested in ordering something similar to the drawing I attached above!
I will be running the 80mm Mustang Cobra MAF. 3 1/2" od. I found this. http://www.siliconeintakes.com/product_ ... 5c08c4dd6a a 180degree aluminum mandrel. You can slash cut them to look like turn downs and then weld together for the Y. Then cope a 3 1/2" straight piece to butt into them and mark and cut the hole in the end. Then weld that together. Im going to look into that.
- sydude
Rob, that could work well. Are you planning on fabbing this up yourself or are you going to have someone else do it? If you do it yourself, are you willing to make units for us as well?yogib wrote:I will be running the 80mm Mustang Cobra MAF. 3 1/2" od. I found this. http://www.siliconeintakes.com/product_ ... 5c08c4dd6a a 180degree aluminum mandrel. You can slash cut them to look like turn downs and then weld together for the Y. Then cope a 3 1/2" straight piece to butt into them and mark and cut the hole in the end. Then weld that together. Im going to look into that.
Hey guys - I didn't spend more than 15 seconds looking at this - so I'm sure the dims probably aren't right, but here's another place to look for parts...
http://www.mandrel-bends.com/catalog/co ... d92222752f
http://www.mandrel-bends.com/catalog/?g ... gwodi22RAg
monkei
Yeah, I may just take this one http://www.mandrel-bends.com/catalog/co ... -1491.html and have the 3" out flared to suit, but it kinda depends on whether or not the dual tube spacing is good for the TB.
Another place to look for these type of stainless 2-1 merge collectors is Burns Stainless LLC
Burns stainless is $$$$$$$$$$$$$$$$$$$$$$$$ though. They are (or were maybe??) right around the corner from my shop and I only use them as a VERY last resort. WAY too expensive!
- sydude
I called them, and he said that while these units are made using in-stock parts, they are actually custom made for each order. So in fact, they will make the spacing between the two tubes to our spec. Also, you'll notice that the 3" single outlet side has no flange to clamp the hose on, but they will weld on a beaded section of straight pipe onto that end for another $20 or so. But that puts you right back into the $95 price I got from the other vendor.monkei wrote:Yeah, I may just take this one http://www.mandrel-bends.com/catalog/co ... -1491.html and have the 3" out flared to suit, but it kinda depends on whether or not the dual tube spacing is good for the TB.
2, 56 mm tubes feeding 1, 80 mm tube is restrictive is portmatched within 2%. Did I misunderstand?sydude wrote:Without any success, I've been looking for a better off-the-shelf alternative for the undersized plastic 'Y' pipe that everyone seems to be using to connect our single mass-air meters to our twin-blade throttle bodies, as I believe that the current 'Y' pipe must be restrictive - it's just waaay smaller in diameter than my 80mm mass-air meter or my twin 56mm throttle body.
2x56mm bores = 4926mm^2
1x80mm bore = 5026mm^2
- sydude
Yes, that's not what I meant. I'm talking about the bore size differences between the stock plastic wye pipe and the much larger bore sizes of the throttle bodies and mass-air meters. I don't have one at hand to measure, but eyeballing it it looks like it's got a 50mm opening on the single inlet side coming from the mass-air meter.shockseals.com wrote:2, 56 mm tubes feeding 1, 80 mm tube is restrictive is portmatched within 2%. Did I misunderstand?sydude wrote:Without any success, I've been looking for a better off-the-shelf alternative for the undersized plastic 'Y' pipe that everyone seems to be using to connect our single mass-air meters to our twin-blade throttle bodies, as I believe that the current 'Y' pipe must be restrictive - it's just waaay smaller in diameter than my 80mm mass-air meter or my twin 56mm throttle body.
monkei
Yeah, sounds about right. I'll be keepin' an eye on this thread. I definitely need to find something better than the crappy factory plastic Y.sydude wrote:I called them, and he said that while these units are made using in-stock parts, they are actually custom made for each order. So in fact, they will make the spacing between the two tubes to our spec. Also, you'll notice that the 3" single outlet side has no flange to clamp the hose on, but they will weld on a beaded section of straight pipe onto that end for another $20 or so. But that puts you right back into the $95 price I got from the other vendor.
