Brian's '96
shaner17
Bronco Info: 1984 Bronco
Re: Brian's '96
Post by shaner17 »
Awsome Yikes! Congrats!
Re: Brian's '96
Thanks guys! Not out of the woods yet. Gotta diagnose the scary noise and why the alternator isn't charging. Could be my electrical genius. The springs are way too soft. Thing is sitting 3-4" too low. Yeow! Maybe I should just put some super long shackles in the rear and call it a day.
ryan B
Bronco Info: prerunner
Re: Brian's '96
Post by ryan B »
Nice work getting her running!
Re: Brian's '96
You have a 3G alt correct? It is a way simple setup. Voltage sense and main output. Small photo but gets the job done:
http://i119.photobucket.com/albums/o127 ... e-alt2.jpg
convoy
Re: Brian's '96
Post by convoy »
Brian the height looks fine in the pic, 3-4" higher might be alot of lift and alignment issues. How much bump do you have right now?
Re: Brian's '96
looks great.......I may have missed it but are you talking front or rear...is to soft and low?
Re: Brian's '96
philofab wrote:You have a 3G alt correct? It is a way simple setup. Voltage sense and main output. Small photo but gets the job done:
Thanks Philo. My b-n-law stopped by and got me straightened out on it. I'll confess to my actions after a couple beers by the campfire at Pismo!
Re: Brian's '96
convoy wrote:Brian the height looks fine in the pic, 3-4" higher might be alot of lift and alignment issues. How much bump do you have right now?
I should have taken a picture from the front. That picture was deceiving. It was sitting at 7+ dgr's camber. Interesting enough, I put 150psi of nitrogen in the shocks and gave the coils another 1/4" of preload, drove it around for 10-15 miles and now it's sitting almost where it was before all this chaos began. I'm a happy guy! The back end was super stiff and needed a few good hits to loosen it up.
Re: Brian's '96
funinthesun95 wrote:looks great.......I may have missed it but are you talking front or rear...is to soft and low?
The front. Still a tad low, but i think I'll go a little longer on the shackles to compensate.
Re: Brian's '96
Oh...and it's officially a grocery getter and not a driveway queen anymore. WOOOOHOOOOOOOOOO!!
Re: Brian's '96
nice!
Re: Brian's '96
Pictures dammit!
Re: Brian's '96
By the way,never drive on or extend your uncharged shocks. You'll need to check them for air now.
convoy
Re: Brian's '96
Post by convoy »
B,
Too much toe-in will lower the front end 2"-3" easy with coilovers.
Re: Brian's '96
Post by shockseals.com »
If 1.25" shaft every 100 psi = 123 lbs of shaft force (preload)
If 1.00" shaft every 100 psi = 78 lbs of shaft force(preload)
Easy way to cheat for wrong spring rate.
Re: Brian's '96
They're 1.125" shafts... so somewhere in the middle.
Re: Brian's '96
yikes wrote:Oh...and it's officially a grocery getter and not a driveway queen anymore. WOOOOHOOOOOOOOOO!!
Wow B, that look fantastic! I can't wait to see it run! I'm so stoked for you... I certainly know the joy of seeing all that work pay off! Congrats!!! And, well done Amigo!!!
Re: Brian's '96
Thanks Tom! Hope you can make it out to Pismo.
Now for some more whoring, just to appease Nick.
Re: Brian's '96
Nice!
Re: Brian's '96
drive way shots ROCK!! you shout go out and wash and take some more! :lol:
