Brian's '96
Re: Brian's '96
Fancy!
Polarcub
Re: Brian's '96
Post by Polarcub »
Brian, great to see you are almost there. Everything is looking really good as always. Cant wait to see how you like the new setup and how you will need to adjust etc.
Jeremy
convoy
Re: Brian's '96
Post by convoy »
yikes wrote: more porting on the front u joint
B,
Have you grinded any material from the u-joint/shaft before? I would be very interested to know what the stock max. angle is and what you are able to acheive.
93Bronquito
Bronco Info: 93 Bronco 351w 35's full glass and some goodies
Re: Brian's '96
Post by 93Bronquito »
Im in the same boat, mine snaps off ever time I go on a good run. What would you charge for one of them things for me? The coil mount that is...
Re: Brian's '96
B,
I removed a bit of material with the previous set up Griffin. Now there's a couple of inches more droop, so it's binding in one area just a tad. Haven't checked the angles, but I'll do that the next time it's in the air.
Re: Brian's '96
93Bronquito wrote:Im in the same boat, mine snaps off ever time I go on a good run. What would you charge for one of them things for me? The coil mount that is...
I'm not touching anything until my Bronco is ready for the dirt. It's been 1 1/2 years since I've driven it, so all side jobs are out until the time comes again. Hit me up again after Pismo if you still need one and I'll be more than happy to hook it up.
Re: Brian's '96
Got the bracket for the air filter done tonight. One more thing down!
Re: Brian's '96
Hey Brian, if I remember correct, the shorter the intake the less torque / more hp the longer the intake the more torque you get. Kinda random...
Re: Brian's '96
Good point; however, for now I'm just trying to make things fit. This is certainly not the set up I'm dreaming about.
Polarcub
Re: Brian's '96
Post by Polarcub »
Looks good B, I need to come up with a bracket for mine as well. Will you have the bronco ready for the Dec race?
Jeremy
Re: Brian's '96
Polarcub wrote:Looks good B, I need to come up with a bracket for mine as well. Will you have the bronco ready for the Dec race?
Thanks Jer. The December race is a bit too close. I'm planning on the Pismo trip as the first real outing. Hoping to head out to Barstow to tune the front shocks the week after Christmas. Still a lot of work to be done before this thing is solid.
Re: Brian's '96
Haven't got much done the last few days, but finished up the bracket for the air cleaner.
Re: Brian's '96
yikes wrote:Haven't got much done the last few days, but finished up the bracket for the air cleaner.
Well then get off the internet and get back to work!!!!!
Time to take my own advice :oops:
Polarcub
Re: Brian's '96
Post by Polarcub »
Let me know when you head out if I have the gas money I will join you.
Jeremy
Re: Brian's '96
Ditto!! Would love to see the machine in action!
Re: Brian's '96
Damn Brian not only is it a nice design I have to give you props for nice rattle can work, lol. Keep the pics coming and get it done.
Re: Brian's '96
Well, shiz! After sitting on the garage floor for a few months I'm finally ready to get the T-case swapped in. It was seeping a bit, so I bought seals and cracked it open to re-glue the case. Much to my dismay, the anti-rotation plate to the pump was broken and laying in the bottom of the case. I doubt parts stores carry these things, but I guess it's worth a try. Bahhhhhh!
Re: Brian's '96
Take it out of you electric t-case. That part should be the same.
Re: Brian's '96
Good idea.
Re: Brian's '96
The range hub is quite warn and beat up. Probably needs to be replaced as well.
