my 1984 FSB
yogib
my 1984 FSB
Post by yogib »
Here,s my 84 converted to newer style glass.Full cage,prp seats,94 351w,C-6,trussed 9-inch,full array Autometers,etc..
robs bronco 008.jpg (92.07 KiB) Viewed 2635 times
robs bronco 006.jpg (94.45 KiB) Viewed 2635 times
robs bronco 004.jpg (90.34 KiB) Viewed 2635 times
Re: my 1984 FSB
nice rob,its about time you posted it up here. it needs some dirt in the fender wells......
yogib
Re: my 1984 FSB
Post by yogib »
Ya I need some newer photos.These are right after assembly from paint shop.Still needed alignment done.Had the stink bug stance.Have fixxed that since this photo.I have,nt even been Off-road with it yet.Need them Deavers and my front bumps still.If the Oregon race in Paisely happens it will for sure be there to Pre-run if there is one.
yogib
61mm BBK TB and ported intake!
Post by yogib »
Ported/Port matched a factory 5.8 intake. Alot to be had as far as flow near the transition from intake to heads.There was a 1/8" all the way around the port that can be removed.Picked up a new BBK 61mm x2 T. body to go with the better flow and some reconed 24lb. injectors.As well as a Adjustable F. regulator.
robs bronco 020.jpg (67.46 KiB) Viewed 2627 times
robs bronco 019.jpg (64.34 KiB) Viewed 2627 times
yogib
Re: my 1984 FSB
Post by yogib »
The latest pics of the bronco.
robs bronco 059.jpg (81.31 KiB) Viewed 2552 times
robs bronco 058.jpg (99.1 KiB) Viewed 2552 times
Re: my 1984 FSB
great job on it it looks VERY nice.i really like the color
Re: my 1984 FSB
Wow, that looks great Yogi!
redwagon
Re: my 1984 FSB
Post by redwagon »
that is one beautiful bronco.
Re: my 1984 FSB
Damn smokey!! That is one HAWT looking bronco! Well done!!
Rednek Renegade
Re: my 1984 FSB
Post by Rednek Renegade »
Looks great! Any pics of the rear bumper that arent in profile view? And what R.A.'s are you runnin?
Project el cheap-o
yogib
Re: my 1984 FSB
Post by yogib »
Rear bumper and interior shot.
robs bronco 009.jpg (72 KiB) Viewed 2501 times
robs bronco 008.jpg (92.07 KiB) Viewed 2501 times
yogib
Re: my 1984 FSB
Post by yogib »
Radius arms are built by a friend of mine.Kevin who built the two badass broncos that i posted pics of.They are setup with threaded ends for future heims.And have a .180 wall main tubes with .120 wall upper tubes (dom).The bumper has welded on tabs for backup lights.And a receiver tube.Kevin built the bumpers as well with my help.I was shop Bit#$ grind,fit,cut.
sydude
Re: my 1984 FSB
Post by sydude »
Hi Rob, hope you've been well. Two quick questions if you can please - are your tires 35's or 37's? Also, how did you prep and paint your top, and how has it been holding up?
Thanks-
Sy
yogib
Re: my 1984 FSB
Post by yogib »
Sorry Sy have,nt been on here in awhile.Been tinkering with my new to me 06 CRF450.To answer your questions.1. 35" BFG MT,s 2.I D-ayed the texture off of the top with 400 grit,and then finished it out with 400 wet sand.Probably the hard way to do it.But as you can see she looks purty shiny.As far as holding up.Prices in Molalla,Ore. did a awesome job on the paint.The chassis has,nt been tested yet.Ive been pretty broke and havent been able to get my rear deavers or build the 408w that I want before it goes out and plays.Some day it will get out and catch some air.
sydude
Re: my 1984 FSB
Post by sydude »
Thank you very much Rob, your top does look awesome - I'm doing this same thing. And if it makes you feel better, I am in the broke camp as well - in fact I 'm so broke I think I may be the head counselor. Here's to better times financially.. Image
yogib
Re: my 1984 FSB
Post by yogib »
Well its been awhile but I hope to have some new pics soon.I installed some ALM. heads and roller rockers.installed a adjustable fuel pressure regulator and 24Lb. injectors.Next will be converting to Mass Air. Here,s my Super Motors page with pics of the head swap and roller Rockers. https://www.supermotors.net/registry/22759
