Looking for IDEAS on my Light bar for my roof rack light PLUG . Looking for a suggestion what people are using and a location for clean install. Just wondering where the best location would be. PICTURES OR SUGGESTION would be great.
Thinking using something similar to these[
attachment=0]Electrial through bulkhead.jpg[/attachment]
Looking for recommendations for light bar electrical bulkhead fittings
- Cactus Cooler
- Electrial through bulkhead.jpg (49.41 KiB) Viewed 141878 times
- Cactus Cooler
Re: Looking for recommendations for light bar electrical bulkhead fittings
best location to mount this, not sure if it should be on the metal roof of the Bronco cab of in the the fiberglass shell?
I don't use an overhead light bar, but I often have a star link dish on the roof and almost always wire extra circuits for future growth... I'm going to put this directly above the dome lamp hole for easy access / service.
https://www.customconnectorkits.com/pro ... p24-18-8pn
https://www.customconnectorkits.com/pro ... p26-18-8sn
https://www.customconnectorkits.com/pro ... 18bt-90-bk
P.S. I use Custom Connector Kits for most of my connector needs. Super helpful folks with tons of inventory.
- Cactus Cooler
Sweet thats what I was looking for Thanks
Bulkhead connectors are pretty common. For the easiest install find the ones with pigtails attached on both sides. The result is no need installing the pins and no need for a special tool. No need to buy the expensive aircraft quality. Do a Google search for "bulkhead connectors with pigtails". I have used several different brands with 2 pins, 4 pins and 7 pins
- Becks_Bronco
I like this!! and there's a dust cap option for when its not being used. I also have the crimper and pins for these. Great website resource!SteveG wrote: ↑Wed Mar 19, 2025 8:12 amI don't use an overhead light bar, but I often have a star link dish on the roof and almost always wire extra circuits for future growth... I'm going to put this directly above the dome lamp hole for easy access / service.
- Cactus Cooler
thumbs up
