1996 Eddie Bauer
- Becks_Bronco
- ESHALLBETTER
Re: 1996 Eddie Bauer
Dude - I love the way this thing is turning out.
Peattie
- Bronco Info: 1986, 351w, C&T beams, beadlocks, 37" BFG's
This has turned out great, and I'm jealous of all the billet parts
franklin90
- Bronco Info: 1991 ford bronco XLT
DUDE YES!! So stoked to see this thread back and alive!
franklin90
No more parking brake?
- Becks_Bronco
Nope. They offer a parking brake caliper, and I may swap to it at some point. So far haven't felt the need for it. If anything, with the discs I might install a line lock instead.
- Becks_Bronco
Same! I'm really happy with how it's come out.
- Becks_Bronco
- Becks_Bronco
You talked me into it!
Pickuptrucker
looking good
- Becks_Bronco
- Becks_Bronco
The battery and cage you see on the left is a 50ah 12v Lithium battery. The mount was designed by Derald Bates, and cut by Send Cut Send. Crudely bent it up on a brake, and that battery isn't going anywhere!
It has a built in bracket for the Renogy DC/DC Charge Controller. Allows dual input from both the truck's alternator as well as solar. When solar is active, and the the house battery is charged, it will trickle charge the starting battery, but won't drain it to keep the house battery full. Currently running the alternator input through my sPod for additional low voltage protection and solid state self resetting relays/fuses for protection.
Wiring is pretty easy at the controller. Common ground for everything. Solar + in, alternator + in, and battery lead.
Wiring from the engine bay to the rear is all under the paneling, and added an Anderson plug so it's still modular and removable.
Wire from the plug to the charge controller is held down with p-clamps to keep things from jostling or getting pinched.
For the lead from the battery to the fridge itself, I added a fuse, in addition to the BMS in the battery and the short circuit protection built into the charge controller as well as the sPod. Really don't want anything having the ability to start a fire... I snipped the 12v cig plug adaptor off the fridge cable and used a good Deutsch connector to make things easy to service.
- Becks_Bronco
- Becks_Bronco
- Becks_Bronco
- Becks_Bronco
A 2000 mile trip through Las Vegas > Rhyolite/Beatty NV, Tonopah NV, Goldfield NV, Eureka NV, Ely NV, Kanab UT, Zion NP, Flagstaff AZ, Grand Canyon, Oatman AZ, running Route 66 from Oatman to Amboy. Ran sections of the Pony Express, and closed/washed out sections of Route 66. Bronco performed flawlessly.
- Becks_Bronco
- Becks_Bronco
- Becks_Bronco
