Nothing special class3 pics
Testing 1,2,3
I might be a little out of build order given I'm playing catch up, but here's more!
Panels before paint
stupid suv.png (584.87 KiB) Viewed 27554 times
Prep help
custom tool holder.png (676.95 KiB) Viewed 27554 times
primed and seam sealed
primed and sealed.png (561.5 KiB) Viewed 27554 times
exterior tub painting:
tub paint 1.png (671.18 KiB) Viewed 27554 times
tub paint 2.png (572.37 KiB) Viewed 27554 times
built a front bumper
bumper 1.png (583.95 KiB) Viewed 27553 times
bumper 2.png (609.56 KiB) Viewed 27553 times
bumper 3.png (482.17 KiB) Viewed 27553 times
bumper weld.png (466.76 KiB) Viewed 27553 times
Then it was time to put all these parts I've been hording for 15 years back on the truck!
batts and cell.png (616.12 KiB) Viewed 27549 times
Plumbing and wiring going back in
plumbing and wiring.png (495.32 KiB) Viewed 27549 times
Bolting shocks and panels in
front assembly.png (295.67 KiB) Viewed 27549 times
front assembly2.png (576.51 KiB) Viewed 27549 times
rear bumps.png (643.95 KiB) Viewed 27549 times
more coolers and radiator gaurds
rad and coolers.png (678.46 KiB) Viewed 27549 times
fabbed up a cross member
shock brace.png (544.84 KiB) Viewed 27549 times
......at this point we were in crunch time to KOH - full panic had set in
threw in some more wiring!
wire mess.png (622.3 KiB) Viewed 27549 times
then fabbed up the twin stick operation
twin stick2.png (490.98 KiB) Viewed 27549 times
twin stick.png (513.17 KiB) Viewed 27549 times
twin stick lever 2.png (410.3 KiB) Viewed 27549 times
I can jam it in and out of 4H on the fly. 4L is on the co-dog side. If we need 4 low he's probably getting out anyway.....
twin stick lever.png (518.08 KiB) Viewed 27549 times
Put the seats and "interior" back in the truck to complete the (opposite of a) luxury prerunner feel
Fabbed up a quick spare tire mount just so I'd have one out at KOH. I want to build a dual swing out rack later but this fit the need and the timeline.
quick rack.png (544.83 KiB) Viewed 27549 times
At this point it was starting to look promising... I wasn't sleeping, and hadn't seen my family for days....
loaded up and rolled out!
koh bound.png (531.42 KiB) Viewed 27549 times
made it!
High fived my bronco bro. We made a bet the year prior committing to have both Broncos there this year. We both won.
bronco bros.png (514.56 KiB) Viewed 27549 times
having it out for the first time was awesome....it's been in the works a lonnnnnnngggggggg time....
Broke some stuff we could fix...
fix or repair daily.png (485.47 KiB) Viewed 27549 times
stocked up on desert karma.
desert karma.png (563.89 KiB) Viewed 27549 times
Then broke some stuff we couldn't fix....
Dang! What couldn't you fix?
Broke the steering rod with the bend in it. Murphy's Law also dictated that when the broken parts went tumbling under the truck it would center punch the oil filter and wipe that out. lol
Your bronco looks killer. I'd say 90% of the time, the first trip ends with a broken something. Can I ask what may have caused the break of the tie rod?
toddz69
Post by toddz69 »
Glad to see it's out on the trails under its own power though!
Pickuptrucker
Post by Pickuptrucker »
yeah we definitely need to see the pics!
hobbyturnedobsession wrote: ↑
Thu May 02, 2024 6:17 am
I executed the first steering rod poorly, and was pushing the truck pretty hard. About 60-65 MPH through some pretty good bumps. I used 1.5 x.120 wall then sleeved and capped it with 1.75 x .120 with an internal gusset. The internal gusset was not shaped right, and too short, and the tie rod split at the bend where the gusset ended and the "cap" was welded.
The new tie rod is one piece of 1.5 x .250 wall 4130 and I've had no problems.
I have in car video from right before it happened, but I'm not sure how to post it.
Dang!!
flyinbronco
HuckMASTER
Post by flyinbronco »
Congrats on getting it in the dirt. It looks bad ass Eric.
ESHALLBETTER wrote: ↑
Mon May 13, 2024 12:46 pm
Thank you for the info, I built my swing steering, and ran .120 1.5 tubing and was contemplating reinforcing. I will do that.
Took the Bronco out over the weekend and ran the Geiser loop. Really wet and sloppy and a single blown fuse was the only issue all day! I posted some videos on my Instagram. Micheal_Honcho
B and F1.jpg (132.39 KiB) Viewed 24695 times
road jump.jpg (136.23 KiB) Viewed 24695 times
