80 - 96 fuel flap door bolts.
I need a half dozen 80 - 96 fuel flap door bolts. They are some weird thread no-one stocks in my neck of the woods. If you have any, let me know.
24hours
Re: 80 - 96 fuel flap door bolts.
I can go look at our junk yard, if your willing to post up those measurements you said you would on the coil buckets.
I can look in my junkyards too - what size wrench do I need to take them off?
24hours
Awesome. I’ll go look Monday.
I’m not sure if I’m understanding exactly what you need. I looked at my local yard and all of the fuel doors are attached to the body by some riveted studs. When I look on the backside, there are some nuts there but they’re definitely larger than 8 mm or 5/16. Is that what you’re looking for?
I think only the 80 - 86 have 2 very small thread bolts holding the flap to the bedside, with an 8mm hex head. Later ones are riveted (I think). My 84 F100 and my brother's 82 Bronco both have the small 8mm hex bolts holding the fuel flap door on. Hope that helps.toddz69 wrote: ↑Sun Mar 05, 2023 11:02 amI’m not sure if I’m understanding exactly what you need. I looked at my local yard and all of the fuel doors are attached to the body by some riveted studs. When I look on the backside, there are some nuts there but they’re definitely larger than 8 mm or 5/16. Is that what you’re looking for?
OK - that makes sense. I didn't look at any of those trucks yesterday - only the 87-91 trucks and 92-96 models and they were all riveted. I saw your title said 80-96 so I assumed they might all be the same. I'll keep looking!AussieRod wrote: ↑Mon Mar 06, 2023 2:07 amI think only the 80 - 86 have 2 very small thread bolts holding the flap to the bedside, with an 8mm hex head. Later ones are riveted (I think). My 84 F100 and my brother's 82 Bronco both have the small 8mm hex bolts holding the fuel flap door on. Hope that helps.toddz69 wrote: ↑Sun Mar 05, 2023 11:02 amI’m not sure if I’m understanding exactly what you need. I looked at my local yard and all of the fuel doors are attached to the body by some riveted studs. When I look on the backside, there are some nuts there but they’re definitely larger than 8 mm or 5/16. Is that what you’re looking for?
So did I, apparently. The later 87 on must be riveted.toddz69 wrote: ↑Mon Mar 06, 2023 9:36 amOK - that makes sense. I didn't look at any of those trucks yesterday - only the 87-91 trucks and 92-96 models and they were all riveted. I saw your title said 80-96 so I assumed they might all be the same. I'll keep looking!AussieRod wrote: ↑Mon Mar 06, 2023 2:07 amI think only the 80 - 86 have 2 very small thread bolts holding the flap to the bedside, with an 8mm hex head. Later ones are riveted (I think). My 84 F100 and my brother's 82 Bronco both have the small 8mm hex bolts holding the fuel flap door on. Hope that helps.toddz69 wrote: ↑Sun Mar 05, 2023 11:02 amI’m not sure if I’m understanding exactly what you need. I looked at my local yard and all of the fuel doors are attached to the body by some riveted studs. When I look on the backside, there are some nuts there but they’re definitely larger than 8 mm or 5/16. Is that what you’re looking for?
Ok - I got half a dozen of the screws for you yesterday. Been a long time since I’ve sent anything to Australia so send me a DM with your info and I’ll see about options in getting them to you.
Rod Pearce
51 Williams Rd,
Myers Flat, Victoria Australia 3556
If they do a soft pack (bubble wrap protected envelope), that should suffice. Let me know what it's cost you and I'll paypal you (I'll pay all fees).
Semi late to the party here, but Rod, I can play master postman again if needed = Todd can send them here and I can send you everything in one box. Just let me know. Oh, and it may take a bit for me to reply due to schedule right now - which I'm sure you've noticed on your last PM Rod! I signed in just now to finally get to that
If you’re sending other stuff to him, just let me know your addy and I’ll send them to you.
@ Chasetruck754: That'll work for me if it's ok with Todd.
@ Toddz69: Let me know what I owe you and I'll fix it up once I get home.
Thanks for the help, guys.
24hours
Glad to see this get sorted!
I've not long got home from 10 days at the mine and I'm wrecked. At 60, it's hard work with the 12 hour+ days and 100 degree days. I have a day off tomorrow, so once I get the F100 out of the garage in the morning, I'll pull a coil bucket and throw you some measurements as promised.
24hours
I hear you. I’m a 51 year old fisherman, the work, weather and age doesn’t make it easy. Time is a thief.
