But all two wheel drive!! Lets see that TTB D50 Crew Cab!
They have always been where it's at! 4 seaters are cool for bringing friends along with ya!philofab wrote:Apparently crew cabs are in...
Ask away. You only have 9 now. Hahaha.04yfzkid wrote:Hey philo, I have been trying to find more pics of your truck for a while! Finally I found your build thread. This thing is definitely rad!
I have close to 10 questions, any chance you could try to answer some for me?
The front suspension is 1" forward over stock and up travel is limited. I could gain more travel with smaller tires.04yfzkid wrote:How well does the front tuck the 37's? I had 35's on my old f-150 and that destroyed my heater box bad lol.
Stops fine, I used to tow 10K with it all the time. I will lock the tires up if I want to. Brakes are way better on 1 tons than 1/2 tons.04yfzkid wrote:Random, but does it still seem to stop ok with the 37's?
This has been done with limited success in other trucks I've seen. I'm not sure how much flare the rear glass is, it originally came from "Black Betty", a Camburg extra cab truck. The truck has evil 2" wheel spacers on the back right now. I hope to be able to widen a sterling axle by 6"-8" eventually. I should note that the H2 wheel is offset inward quite a bit. Bad for width but good for tie-rods and wheel bearings.04yfzkid wrote:How wide is the rear glass incase I missed it? Also I noticed it seemed to tuck pretty well, do you think it would be possible to run a stock bed with glass, and cut out the wheel wells for some bigger tubs?
I'm not worried about the lack of ground clearance. My Bronco does ok with the same tank and it's not nearly as long. I think the truck will have more issues with high centering.04yfzkid wrote:I noticed you got a bigger rear tank, are you concerned about the ground clearance at all? I am worried about it on my truck for when I go 4x'in. Then again I guess drop hangers still probably hang down lower
I would have a good spring maker build custom leaves. The Giant leaves are very soft and 2.5 inches wide. Not good for a truck with over 400ft pounds of torque, 37" tires, and a lot of weight.04yfzkid wrote:I was thinking about running some 64's on my truck, but I am not sure if it's going to be too much weight for them. I have heard geoff doesn't make them for the new f-1's because they weigh too much lol
04yfzkid wrote:I know had more questions, but I am totally forgetting them.
I didn't mean to. Remember there is more than one way to do everything.04yfzkid wrote:Interesting, that just threw a huge curve ball into my plans lol.
What does Steve's truck look like now? I bought this glass off of him exactly a year ago.04yfzkid wrote:Well I am planning on running method wheels so they should have a zero offset and should help a little bit. Didn't realize you got the glass of Steve's truck. I liked that truck and stared at it a lot when it was at my buddy Jonnie's shop a couple months ago.
As far as linking it or leaves, that is a difficult question. Kinda depends on your pocketbook and use of the truck. I'm kinda a pro-leaf spring type of guy. I don't think I would use an off the shelf spring, have Deaver or someone else make a custom pack and convert to spring under possibly with a link for axle wrap. The D50 beams should take any abuse you throw at them. They have way beefier components than the already proven stout D44 stuff. Larger snout, bigger wheel bearings, wider ball joint spread, stronger ball joints, wider wheel bearing spread, tougher knuckles, ect.04yfzkid wrote:So would you advise just trying to buy a super duty pack like you did, and try to make it work, or just link it with the bed still? I am not sure how hard I am going to push it with the d50 beams, but I would imagine they will be pretty strong after they get extended.
Philo,philofab wrote: As far as linking it or leaves, that is a difficult question. Kinda depends on your pocketbook and use of the truck. I'm kinda a pro-leaf spring type of guy. I don't think I would use an off the shelf spring, have Deaver or someone else make a custom pack and convert to spring under possibly with a link for axle wrap. The D50 beams should take any abuse you throw at them. They have way beefier components than the already proven stout D44 stuff. Larger snout, bigger wheel bearings, wider ball joint spread, stronger ball joints, wider wheel bearing spread, tougher knuckles, ect.
I'm using radius arms and Bilstien 9300 coilovers with the ACV valve in front. I thought the question was referring to the rear suspension. I want a solid 18" front and rear.BajaF250 wrote:Philo,
How much travel are you shooting for? This'll make a big difference in your decision. As you increase your travel you'll introduce leaf spring twisting dynamics into the equation. I went throught this when I first started with my truck. The first suspension upgrade I did on the BajaF250 was to add 4" nationals to the the front. John cut the axle housings to compensate for the increased angularity of the axle housings. But, you still can't negate the twisting dynamics as the front suspension travels between bump and droop. So, if you aren't designing a lot of travel, I think leafs are great, but if you're going for more travel, I think you might be disappointed and should consider either linking or radius arms.
I'd focus less on travel numbers and more on damping. The Scaroni Excursion only had 12" of front end travel and 16" of rear. As I'm told, it was very plush in the rough.philofab wrote:I want a solid 18" front and rear.
I remember seeing that thing at the Parker 425 years ago when BITD took it over. Surprising to hear it only has 12" in the front.SteveG wrote:I'd focus less on travel numbers and more on damping. The Scaroni Excursion only had 12" of front end travel and 16" of rear. As I'm told, it was very plush in the rough.philofab wrote:I want a solid 18" front and rear.
http://www.off-road.com/trucks-4x4/proj ... ?printable
Hopefully it won't take you near as long as it did me... !philofab wrote:Well, I put the 33 gallon Bronco tank in the crew today but I don't think I'm going to keep it. My rear frame rails would allow a 3" wider and 4" longer tank, plus I have room above where the bed would be. I think I will end up building a stainless 16ga tank that fits in there exactly with a 3/16 aluminum skid. Should net me about 60 gallons. What's 400 pounds of fuel going to do for traction???
