deaver Q80Madmaxwell87 wrote: ↑Fri Sep 11, 2020 10:27 amWhat rear springs are you running?ThrustMaster wrote: ↑Fri Sep 11, 2020 8:14 amI have the threat one and like it so far. Running gen 1 raptor shocks and stock axle mounts and they are limiting droop travel at the moment. i have lots of work to do though.
Rear shock mounts
ThrustMaster
- Bronco Info: 1985 Bronco Victorian 2 tone blue stock at the moment
Re: Rear shock mounts
Madmaxwell87
- Bronco Info: White 1993 5.8l XLT
Thanks! So about 3"s higher than my stock springs. Raptor shocks might work well for me then assuming they're compressed length is short enough.
White 93 5.8L XLT
ThrustMaster
the q80's sit pretty high, so only use them if you plan on haveing a good amount of weight in the rear.
On the trucks that ridiculous 2 tank setup is the issue- you can chop the tank and weld it which is dumb imo, delete the front tank completely and run a 19 in the rear —or put a 33 gal bronco tank in or a 38 gallon tank. Personally I’d put a 33 or 38 gallon in there, and pay a body guy to cover the extra fuel door. Then if your super anal you find a F150 with a factory front delete and you put this kewl part in the dash to clean it all up!
- F1915531-459A-4BBF-A0CC-ECA1FBAE52D8.jpeg (282.86 KiB) Viewed 2413 times
