In need of two striker bolts as my junkyard does not have any broncos currently. I used a cheap bushing which caused the bolt to not go in nearly enough and my tailgate is stuck/sagging on the washer. In case I have to cut them out want a set on hand. I'm in Phoenix shipping is to 85296.
Brandon
Tailgate striker bolts
Re: Tailgate striker bolts
I may have these but can't look currently. When will you know if you have to cut?
Steve,
These show for the later model trucks. Are they all the same? Planning to cut within the next week so if you would let me know if they work and if not see if Chase has some.
Let me know if you need um. I've got a box of random bronco bits in the garage and I'm thinking there's a set or 2 in there. The box is a bit buried, but I can look when needed.
If you can locate them in the next couple days and we can work out payment that would be great. Wish I knew if the ones steve referenced fit but it keeps referring to newer trucks.
I hate to do this to you, but I just spent 20-30 min. looking through my boxes in the garage and they're not there. I must have given them to someone over the years.
Did you see this? Parting a bronco. Maybe he has and can ship. There's a number in the ad to text.
https://www.gofastbroncos.com/forum/vie ... =26&t=9953
I got a couple different sets and nothing worked. If anyone is parting a bronco let me know.
