5.8L Timing Cover Bolt Kit
All,
We need to replace the water pump on one 5.8L and the timing cover on another 5.8L. Both will get a new water pump and new timing cover because they are very prone to corrode.
I always replace the timing cover/water pump bolts when doing this job because they corrode and eventually break. I used to order them from Ford but they're discontinued.
Anyone have experience with one of these kits?
https://www.jegs.com/i/JEGS+Performance ... c0EALw_wcB
Re: 5.8L Timing Cover Bolt Kit
I've just used the doorman kit for my 5.0 5.8 and 7.5 and haven't had an issue. I have had to remove them before and they didn't have a problem. Jegs should be a much better product.
hobbyturnedobsession wrote: ↑
Mon Jun 15, 2020 12:50 pm
Nice. That's good to know.
Did you use the 5.0 kit on the 5.8? Same kit?
1Hondalover
Post by 1Hondalover »
This is what I used on the last water pump Flow Kooler.
IMG_7922 (Large).JPG (246.67 KiB) Viewed 2159 times
Its been a while since I did the kit but if memory serves me correct it is.
Cricket
Bronco Info: '91 F-150 Custom Shortbed, 2WD converting to 4WD with C&T
Post by Cricket »
Late Model Restoration has a kit made by ARP that I used on my 1995 F-150 5.8.
https://lmr.com/item/LTP-8501BHDW/F-150 ... tuds-Bolts
Thanks for the info, guys. I ordered the kit from Jeg’s. It appears to be close to the same as the LMR kit and also made in the USA. I’ll let you know how it fits.
Thanks again!
Mrz181
Bronco Info: 94 bronco 5.8l lightning engine e4od trans 8.8 rear end
Post by Mrz181 »
what timing cover are you going with ? i did one when i first got my bronco has the 5.8l lightning 351w...had to replace due to crank seal leaking....first one i bought one of the bolts didn't line up so i went back with what was in there..dont recall the brand.....just asking because I'm gonna do it again when i go thru the engine
I ordered a pair of these: https://www.summitracing.com/parts/aaf-all90018
A coworker (that was a career master mechanic pre-rugged) saw them at SEMA a few years ago and said their aluminum goods looked really good....
Mrz181
Post by Mrz181 »
ok cool i just looked at my order history and the dorman was first....bolt didn't line up.....went with pioneer which i had originally but needed to replace due to gouges in crank seal location
I have yet to get a crank seal out without cracking a timing cover.
Mrz181
Post by Mrz181 »
yeah it took me awhile trying to get it out ended up pulling the cover off to find previous owner put it in backwards.....funny story i also ended up putting it in backwards just like i remembered it lol
