Willie's.....1992
4WPRusty
- Bronco Info: 1992 Bronco. Caged, Linked and Loud
Re: Willie's.....1992
Back seat upgrade. PRP 45” wide bench, seat heaters and garage fab mount. Please note I am not a fabricator. Please be nice haha.
- BA404064-C4E6-4856-A4E3-FFC66197330A.jpeg (357.23 KiB) Viewed 3874 times
- 83B81A1B-2185-408C-91D7-CDD81201A49A.jpeg (266.22 KiB) Viewed 3874 times
- 351CA766-BBA5-4DFC-8EB5-E5BFFDCA5907.jpeg (272.78 KiB) Viewed 3874 times
- 47011588-24AC-433B-BB01-BF38D6EAF9BD.jpeg (330.92 KiB) Viewed 3874 times
Pickuptrucker
Looking rad!
Cool idea on the brake light! And that seat mounts looks pretty dang good for not being a fabricator.
4WPRusty
Thanks, desk jockey by day at 4WP. I have some fab tools but I haven't welded or anything in years.ChaseTruck754 wrote:Cool idea on the brake light! And that seat mounts looks pretty dang good for not being a fabricator.
4WPRusty
Back on the tow truck. Damn fuel pump.
- 2FAE85EB-576A-4B9A-86F5-7B052BF138C3.jpeg (228.5 KiB) Viewed 3773 times
- B5BE7880-30F3-42F1-9663-7368920CA960.jpeg (257.82 KiB) Viewed 3773 times
4WPRusty
Back in action. I installed a nice Delphi pump.
- D9BA46B3-A6CE-40C2-90F4-FC82B84313E3.jpeg (188.62 KiB) Viewed 3744 times
- 3F6CD076-CCDE-40F8-830E-7901B4FC27A6.jpeg (336.79 KiB) Viewed 3744 times
- 1CF93B47-2BAE-42C6-A4FC-33E74D8E6D42.jpeg (425.08 KiB) Viewed 3744 times
4WPRusty
Took a run to JV to test out the Pro Comp 40’s. Everything went great with the exception of a bearing growl coming out of the 9”. Time to pull it down and freshen it up.
- D612DC94-030E-446A-8ECA-AF1D025980E2.jpeg (687.25 KiB) Viewed 3554 times
4WPRusty
Method 704 with Pro Comp 40” MT
- F194E588-F924-4C94-920D-AC9745EBD047.jpeg (347.14 KiB) Viewed 3552 times
4WPRusty
I have a few questions for the Bronco Masters.
1. What coolant is the best for this application?
2. What gear oil do you guys prefer and why?
3. Any suggestions on spring rates for rear shocks? It feels stiff in the rear and bucks like crazy.
- CD8F4E16-16A5-4E31-ADE9-68A65368139F.jpeg (448.13 KiB) Viewed 3551 times
do you want to deal with the shocks yourself or do you want a recommendation on someone who can get you fixed up?
You looking for synthetic or not for gear oil? Asking as dont know what traction aid you have.
too many variables especially since you are linked to the axle. typically in my experience if the rear is 'bucking' you dont have enough compression and potentially too much rebound.
spring rate is simple. keep it to 2-3" of pre load in the rear, 1-2'' in the front, with a 100-150 spring rate split.
If synthetic I used royal purple 75w140. Since I have a truetrac now it requires non synthetic and am using 75w140 lucas in the rear.
Pickuptrucker
40's look rad
4WPRusty
If you are local to SoCal.... And Free On July 11th.......
4WPRusty
All things fun must come to an end. I had it dialed but now the transmission wants to take a break. While in JV I noticed it sounded like it was whining, almost like a power steering pump. I checked the fluid twice and it looked fine. I left JV and it seemed to be lugging along. Once I got up to speed it was fine. The shifts from gear to gear seemed longer than normal and slower to engage. I didn't think much of it. I got home and parked it. Yesterday I decided to pick up breakfast for the fam. I fired it up and the whining was still present. But now it was acting odd, if I let the trans pick the shift points automatically it did awful. I was having to bump the gas to get it to shift. So I started to shift it myself but it was very slow to shift between gears. I slowed to make a turn and it stayed in 3rd and would not downshift by itself. When I pulled into my driveway it died and will not idle in gear. Its acting like the torque converter locked up.
Any ideas from the masters?
- funinthesun95
make sure the adjustment at the linkage point on the tranny is putting the tranny into the correct gear. I would also plug into the USSHIFT and see what it is doing.
MLPS RANGE SENSOR NEUTRAL SAFETY SWITCH is what you are checking
4WPRusty
I will do that. I have not pulled the console yet to access the controller. On a separate note, do you know what filter this is?funinthesun95 wrote: ↑Mon Jun 29, 2020 7:01 pmmake sure the adjustment at the linkage point on the tranny is putting the tranny into the correct gear. I would also plug into the USSHIFT and see what it is doing.
