95 F150 - Project Marilyn
- funinthesun95
Re: 95 F150 - Project Marilyn
nice
Rear tail light wiring harness. Trying to delete all of the flexloom and use sheathing as the protective cover.
- A72E1725-C171-4534-B93A-6E0B4B82A878.jpeg (135.88 KiB) Viewed 28143 times
Wanted this posted so I could always have it:
- 159C9448-DBE1-4523-A6C5-94F251B40DEF.jpeg (167.82 KiB) Viewed 28077 times
- F9ED8A62-8ADC-4633-BE88-A5A0DB983CB9.jpeg (132.83 KiB) Viewed 28077 times
What's years is this good through?
I'm guessing '96 OBD II, given the number of ECM pins.RyanDS650X wrote:What's years is this good through?
My 95 truck and 96 bronco have 96 wiring and 96 OBDII computers. Posted this so if I lost my phone, or wanted my own easy to find reference material. I think I’m going to get these printed off and laminated so I have a hard copy reference.
- Becks_Bronco
If you print some off in higher resolution, i would love to have a laminated copy.VintageIronFab wrote:My 95 truck and 96 bronco have 96 wiring and 96 OBDII computers. Posted this so if I lost my phone, or wanted my own easy to find reference material. I think I’m going to get these printed off and laminated so I have a hard copy reference.
Door sill protectors made out of JY sills I’ve cut out, cut down, will finish in Linex and attach via some #10 SS buttonheads.
- A99F1906-E069-4A62-B3F8-1B0A35D3040B.jpeg (762.33 KiB) Viewed 28021 times
- 2AF2F898-16D3-4572-BA43-FD42C252ABDE.jpeg (237.35 KiB) Viewed 28021 times
- 4149109C-A29C-4DB5-B7AD-45C6D4C0429A.jpeg (321.85 KiB) Viewed 28021 times
- Becks_Bronco
Nice! I've never even noticed that spot. I bought replacement plastic trim in billet aluminum. Hopefully they hold up.
Got the door sill protectors aback from Linex and installed. It’s just nice to not feel like you’re crunching a painted surface when going in and out. Highly recommend this method!
- D0072311-7DFD-478B-88F5-41418856DCC8.jpeg (98.06 KiB) Viewed 27918 times
- FD5458B2-235D-4465-ACC2-40E71FE099DE.jpeg (100.7 KiB) Viewed 27918 times
- 68409001-B5FB-416A-97A0-5BC919863D42.jpeg (360.63 KiB) Viewed 27918 times
- 901890A5-2D03-44BA-A0B6-4A56D773B2AF.jpeg (35.08 KiB) Viewed 27918 times
Needed a clean/convenient bracket to hold headsets. Made the bracket out of 1/4” aluminum mainly to keep it from looking spindly and really light in weight. Powdercoated to match of course and held down with a factory Ford light fitted with some LED’s. No obstruction with the view out back (without headsets of course) and is about 14-16” away from your head.
- 11569716-D62C-4F19-B078-7BC92664F888.jpeg (729.33 KiB) Viewed 27900 times
New window sweep install fix—
New window sweeps are a nice update/upgrade/fix but the NOS ones don’t exist and they probably wouldn’t fit due to the 25 yo old door panel slots. So I got tired of them not fitting and just made a couple sporty oblong washers out of some scrap- stainless would be perfect and pop riveted them in place. Fits brand new tight and won’t come loose again!
- E735246E-55CE-4C17-B606-D98682FB97AA.jpeg (486.03 KiB) Viewed 27895 times
- A16D85ED-4E9E-4D46-A7A6-24884A3A3CB0.jpeg (51.59 KiB) Viewed 27895 times
- F567C5CB-BAEA-4A21-BD4D-5AAD1272CD72.jpeg (79.16 KiB) Viewed 27895 times
- Becks_Bronco
Awesome man! What dome light is that?
I think is a Taurus maybe? An Explorer?? It won’t work on a Bronco but the F1 roofline works
- zachwabbit
How you liking the 3-point seat belts so far?
No idea really yet- they are a pita for a daily type use but in the dirt they are probably amazing but we shall see.
- zachwabbit
Ahh. Interesting, I may steal that idea from you for my B2 if it works out
So I got some actual seat time with the 3-point harnesses. So if I could get just a bit of refinement they would be seriously great! Like you are not about to go full cage or you have a Jeep and not full seats to the cage - these really hold you in the seat. If I could get PRP to look at them I think they would be interested in the design.
Finally installed all the inside can tie downs ---- no floating stuff inside the cab! These are from the 2000-ish Chevy Blazers (S-10 size); they are HD pieces that lhave a hole for a 3/8” bolt which is way big/strong enough for the application. The “washers” turned out pretty well and should give a nice secure backing no matter how aggressive the driving gets. All got powdercoated satin black lol!
Those are factory F150 jump seats btw.
- EF1B2C02-CED2-42D1-A9DF-12669A088025.jpeg (404.55 KiB) Viewed 27793 times
- 4A10FD42-FF19-4D25-B939-59C6EDD67A8D.jpeg (415.15 KiB) Viewed 27793 times
- CDF86F56-641A-422D-AB6F-BB9EA42EC194.jpeg (298.61 KiB) Viewed 27793 times
- 0F694C1A-1604-4EF1-99FD-5FB99A0155B4.jpeg (791.6 KiB) Viewed 27793 times
So the first trip was to KOH 2020 and it went fairly well all in all! I pulled her off the trailer and the power steering pump immediately crapped out but I just kinda went with it. Met up with Andy J and some of his buddies -great guys and some killer broncos- and we immediately took off on about a 20 mile pavement drive and about 10-15 more miles in the dirt. Quite frankly the entire time I was terrified! Terrified that I just met these guys in person and I’m driving a truck I have zero time driving— ZERO! She never broke down, died, stalled or was even hard to start— super happy with everything! I was afraid the rearend was too wide for the bedsides but all turned out good and all the fiberglass proved out well! It’s a good feeling I don’t have to re-engineer all the things I’ve toiled over and sweated the details on all this time.
- E243F442-6A13-496A-A448-2237E82AEC31.jpeg (300.28 KiB) Viewed 27792 times
- C0B2AE3D-C9A0-410C-B60B-9BD94CC1C8FC.jpeg (301.8 KiB) Viewed 27792 times
- 0FBC31D0-92FF-4C7B-A683-B685BBDFB05A.jpeg (299.78 KiB) Viewed 27792 times
- 0CFFB644-B39A-4D73-B6C3-2DFB7A799425.jpeg (274.76 KiB) Viewed 27792 times
