Saginaw Pumps W/ Brackets
- S00TLYFE
- Bronco Info: IT RAPTOR NOW
I have 4 more Saginaw pumps with brackets, pulleys, and caps, all work and don’t leak. No hoses, can include hardware for mounting ac compressor. $200 obo picked up in Buena Park, will ship on buyers dime.
7142623674- Travis
7142623674- Travis
- S00TLYFE
Sorry, $150 for GFBers.
I copy pasted this from another forum and forgot to change the price
- S00TLYFE
Bump, sale pending on all the 5.0/5.8 ones,
If anyone here has a 4.9 I do have a setup available, asking $150 as is or $200 if you want a new pump installed
squiggy_bum
- Bronco Info: 1992 Ford Bronco, just starting a prerunner build, planning on 2.5 coil overs up front, stock beams
Re: Saginaw Pumps W/ Brackets
Bought my kit a while ago and just getting around to installing, can you remind me what new hoses I need
- S00TLYFE
Econoline hoses, don’t think you bought from me
- S00TLYFE
Bump, I have 1 5.0/5.8 setup available, as well as 1 4.9 inline 6 setup available, $150 as is or $200 with a reman pump.
- S00TLYFE
Bump, have 1 460 setup and 3 5.0/5.8 setups, back and forth between LA and Huntsville for work in December so let me know. $200 for an installed reman pump, $150 for a complete used setup.
- S00TLYFE
Bump, I have 5 more of these setups for the 5.0/5.8 trucks
$150 with a used pump
$200 with reman
Will ship for additional $50
$200 with reman
- S00TLYFE
Bump, I have 5 setups currently, I can have them assembled and ready to ship/pickup this Sunday
You have a 460 set up that will fit my 77 with v belts?
- S00TLYFE
So I have a 460 setup but it’s for Chris’ new OBS.yikes wrote:You have a 460 set up that will fit my 77 with v belts?
Unfortunately in your case I think we’d have to pull a complete setup (both brackets) and then convert your dentside to serpentine belt setup. Which we can totally do if you’re interested.
That would be cool. Carry one belt and clean up the entire system. I like it.
- S00TLYFE
yikes wrote:That would be cool. Carry one belt and clean up the entire system. I like it.
I’ll be on the look out for a full setup next time I’m out at the junkyards. Taylor and John Haines have figured out the hoses based off the setups I’ve sold them so we should be good to go there as well.
- S00TLYFE
- S00TLYFE
So update on these,
5.0/5.8 setups: come with a reman pump, sandblasted bracket, pulley, and reservoir cap for $250
460 Setups: $300 come with a reman pump, sandblasted bracket, pulley, and reservoir cap for $300 (these are getting hard to find.
I offer steel braided hose sets with AN fittings for an additional $100.
I offer powdercoat as well, text for quotes on that, it varies by color.
Visual aid on the hoses I sell
All brackets now come sandblasted so you don’t end up with some grimey piece that is hard to clean up.
- S00TLYFE
Example of a powdercoated 460 setup for a customer.
Good morning !! So you have a sand blasted 5.8 set up $250, with hoses for $350 ?
- S00TLYFE
Correct $350 for hoses and a complete pump setup. Go ahead and text me 7142623674 and we’ll go over the detailsBajaluv wrote:Good morning !! So you have a sand blasted 5.8 set up $250, with hoses for $350 ?
- S00TLYFE
If you guys are on Instagram, you can follow my page for more info and updates
@donttellmywiferacing
- S00TLYFE
Example of my black steel braided hoses with AN fittings, I can sell these with the complete setup or stand alone for $100
