best tail gate
palmawor
Bronco Info: 96 4x4 bronco. 6" BDS dropped 2" reached leafs. stock engine n tranny.
best tail gate
Post by palmawor »
To purchase... Just shell or with all hardware minus glass. Where to buy on the internet? I've heard its a nightmare to replace a tail gate. Need for 96 bronco. Thanks
Re: best tail gate
We’ll eventually replace the tailgate on Wilson with a fiberglass unit from Autofab.
Re: best tail gate
The Autofab units are very nice. So much lighter.
When you replace it, take to opportunity to ditch the safety switch's.
ThrustMaster
Bronco Info: 1985 Bronco Victorian 2 tone blue stock at the moment
Re: best tail gate
Post by ThrustMaster »
BDKW1 wrote:The Autofab units are very nice. So much lighter.
Any other tailgate tips? I am about to toss out my non functioning rust gate for a functioning one.
Re: best tail gate
Good call. Have you transferred everything yourself? I'm wondering what the time investment is.
1Hondalover
Re: best tail gate
Post by 1Hondalover »
The best tailgate is a working one you don't have to screw with. That said, I too have some tailgates to deal with. Jim & Paige's Bronco needs an Ehmke special, and Mom & Dad's Thanksgiving Bronco needs an OE rehab to include a new outer because the spare tire holder split the seam.
Sounds like we need an Autofab group buy. There's a paint shop right next door to them, so we can get the 'glass shells pre-painted and have a tailgate rehab weekend party at Rugged!
Steven?
Re: best tail gate
1Hondalover wrote:The best tailgate is a working one you don't have to screw with. That said, I too have some tailgates to deal with. Jim & Paige's Bronco needs an Ehmke special, and Mom & Dad's Thanksgiving Bronco needs an OE rehab to include a new outer because the spare tire holder split the seam.
Steven?
Hell no. I'm not wondering how long it will take me. I'm just trying to figure out what it's going to cost to pay someone else to do it!
1Hondalover
Re: best tail gate
Yeah I don't want much to do with the mechanics of it either Steven. Wish I had that kind of time. Let me know if you find someone who knows what they're doing, I may give 'em a crack too.
But there's still that group buy thing......
Re: best tail gate
ThrustMaster wrote:Any other tailgate tips? I am about to toss out my non functioning rust gate for a functioning one.
Yeah, put a brand new factory window motor in it. It really sucks ass when they die in the down position. Only slightly less in the up position.
Re: best tail gate
1Hondalover wrote:Yeah I don't want much to do with the mechanics of it either Steven. Wish I had that kind of time. Let me know if you find someone who knows what they're doing, I may give 'em a crack too.
I can’t imagine the price of the tailgate will drop much, but I have someone in mind to do the swap for us. Maybe we can have him do both for us since the second will be significantly faster after having just done one.
1Hondalover
Re: best tail gate
OK please keep me posted.
Becks_Bronco
Re: best tail gate
Post by Becks_Bronco »
Well, I've replaced everything except the window regulator and motor in mine. It's not SO awful.
If someone wants to replace my oil pan gasket, i'll assemble your tailgate lol.
Is the Autofab one up to the task of the same abuse a steel one would endure? Can it handle the factory spare tire gate? Do slots need to be cut for weather-stripping etc?
Re: best tail gate
The factory tail gates aren't up to holding the spare. I would not attach the spare to any tailgate, much better to go to the bumper. If you put an aluminum panel on them the are pretty sturdy. You can stand and sit on them without issue.
Becks_Bronco
Re: best tail gate
BDKW1 wrote:The factory tail gates aren't up to holding the spare. I would not attach the spare to any tailgate, much better to go to the bumper. If you put an aluminum panel on them the are pretty sturdy. You can stand and sit on them without issue.
Some of the Desolate rigs with the spare tire support seem to be holding up 35’s ok. Same with a couple Solo rigs. Granted, these are single coil over leaf sprung trucks, so they’re not full race bashed rigs either.
best tail gate
The trick is to build a little “step” on the rear bumper that the tire rests some of its weight on.
Seems to hold up fairly well despite the body being on rubber bushings and the bumper solid mounted to the frame.
Becks_Bronco
Re: best tail gate
Tchajagos wrote:The trick is to build a little “step” on the rear bumper that the tire rests some of its weight on.
That's exactly what i was thinking of! Good pictures of it too.
LvSteve
Re: best tail gate
Post by LvSteve »
Travis
Are there any plain to make a kit for oem rear bumpers ?
Bondobob
best tail gate
Post by Bondobob »
The fiberglass “shell” of the tailgate won’t likely hold up to use of the factory tiregate hardware attachment. I’ve been using one of John’s fiberglass tailgates for over 4 years. Only issue i’ve had was that my limit/strap cables were not exact so it loaded the driver side pin more and pulled it in the glass shell. I bought it used and it saw lots of use before I put it my Bronco. Also the nutserts can rust/oxidize.. Mine seized up and I broke a few in disassembly. This might be just a one off since it was used. The insert I’m using is Sanatec HDPE flat”cutting”board. Easy to work with and perfect for cutting limes for that cold beverage.
palmawor
Re: best tail gate
Post by palmawor »
Mine is bowed out from the center as if weight caused the bow when in down position. If you look down to the seal from the inside, there is about an inch in the center. Causing the window to not track up or down and the breaker goes off when trying to use the window. Anybody have any ideas on how to UN-bow a tail gate. I don't have tire mount on tailgate.its crazy to me how many problems these tail gates have.......
Re: best tail gate
The issue I see with the add on tire support step Travis showed is what do you do with a different tire brand, inflation amount or tread wear? You're either going to be heavily preloading the hardware with a newer/more tread/highly inflated tire, or not have the support with the opposite. I guess it is a spare after all, so chances are the same tire will be there for years, but something worth considering.
