HTO'S BRONCO BUILD
Re: HTO'S BRONCO BUILD
You're only working on yours 1 day a week? That was my problem for a long time. Now its home at least I can work on the loose ends. How come the change in motors?
- bajascott
- My belly is my best friend
got fed up with the 351 that i had due to the broken ez outs and rusty bolts.(that is now going to be stripped and sent out and rebuilt for my wifes 66 'stang). this motor has less miles,its carb'd and looks to be in better shape. i am trying to figure out how to run the e4od with it.but it seems that ,that will open up anoth can of worms ,so im trying find a good c-6 to run in it untill i get mine built. you know blah,blah,blah haha
Hahahahah. You going to keep the carb? How come? Why not just use the existing fuel injection and run a c6? They had that combo right?
- bajascott
well i am not happy with the computer systems.i have had so many problems with my broncos electronics,and i want to totally get away from it. i am a simple minded person and i hate not being able work on my own stuff.
That's what a stand alone system if for!
Embrace the snowball my friend...
I'm still working out the bugs in mine. Good to hear you are making headway! Keep me posted.
- bajascott
steve, the snowball i have is packed with rocks.
i will post up some updates soon on my bronco soon...
So I ran a test on my truck, its the map sensor. Sprayed carb cleaner and there is no vacuum leaks. Also, I took out the water temp and put in a manual gauge, will this make a difference?
If you took out the ECT (engine coolant temp) sensor for the ECM it would make a big difference.
Anyone working on their own EFI Ford should buy whichever of these books (preferably both) applies to their vehicle. They have TONS of really useful information and all kinds of great wiring diagrams.
http://www.google.com/products/catalog? ... 8wIwATgA#p
http://search.barnesandnoble.com/Ford-F ... 0837603018
nevermind. it was just the sender
Ok, so I changed the map sensor this weekend and it runs like a top! Until I get a massive fuel leak last night and can't figure out if its the fitting or fuel pressure regulator in the dark... I hate working out the bugs.
Also, theres a line that runs from the charcoal canister to the fuel tank, and another line with a solenoid. Where does the line with the solenoid go to?
- Polarcub
Glad to hear that you got the intial problem fixed...at least the fuel is easier to chase down.
Jeremy
Hahah esp when it leaks as bad as it does.
It goes to the intake. That is a purge solenoid that releases fuel vapors to the motor under certain conditions. There should not be liquid fuel in that line unless you have a habit of topping off/overfilling.hobbyturnedobsession wrote:Also, theres a line that runs from the charcoal canister to the fuel tank, and another line with a solenoid. Where does the line with the solenoid go to?
No it isnt. Just a quesiton because I didnt know where it went. I think I've got a bad regulator or a line cracked. I couldn't tell last night.
Any one know where I can get a y pipe for my bronco? I see them for 5.0s but none for 5.8. At least ones that are CA legal.
Just a thought, will the 5.0L y pipe from Bassani fit on my 5.8L?
No. The deck height between the blocks is different so the heads are slightly farther up and spread apart. I've had several people ask me to build them bit I don't have access to a 5.8 truck or Bronco.hobbyturnedobsession wrote:Just a thought, will the 5.0L y pipe from Bassani fit on my 5.8L?
The exhaust shop wants 750 for a new exhaust system.
