right at 2”Tchajagos wrote:Are you running the inner fenders? I usually have to set the bump with the beams about 2” from the frame in order to turn and not rub the fenders and airbox.
at this time the center joint is not an issue, it has been clearanced quite a bit as welldamon1272 wrote:One last thing to check is if the center U-joint is binding under full droop.
