1994 "Tortilla Getter"
- 450xracer68
- Bronco Info: 1994 Bronco 5.8
Well finally decided I was at that point to start a build thread. After looking for months on the right Bronco that wasn't junked out, I bought a 1994 Bronco from a guy up in Oxnard for a deal I couldn't pass up. Only thing wrong was the A/C didn't work but that was an easy fix!. Original plan was to build a stock sleeper, but since this has been something I have wanted to build as a kid I figured I'd try to make my dream come true!
Front;
4" over front end I built in my shop.
35's
Fox 2.5 Coilovers
Giant Engine Cage
OhhCho Radius Arms & Mounts
Other Misc Things
Solo Roll Cage
Rear:
Undecided really at this point
64" Link Killer was first on the mind
Short Course link style set up
Bypasses
Ford 9" OR Currie Rear end
Front;
35's
Fox 2.5 Coilovers
Giant Engine Cage
Other Misc Things
Solo Roll Cage
Rear:
Bypasses
- 450xracer68
Re: 1994 "Tortilla Getter"
Started to Extend and weld up my beams. Haven't picked up the Tig Torch in a while and it shows.
Plated and adding the truss
Finally got my uniballs and drilled the cups out.
PIcked up these Beauties!
Halfway there, need to mount up and tack Uniballs for 1" Forward location. Cut and turned on the Jig I made. She should be good at a 4" Lift!
Should be Picking up shocks and Engine Cage Tuesday. Then i'll bring the bronco to my shop to start tearing her down.
- redrdr67
- Bronco Info: 1999 F350, 1999 E350, 1995 F150 2WD
Looks great from here. Coming along nicely.
Clean Bronco, clean FAB work !! Off to a great start dude. I say link killer, but I’m a fan
- Bronco Info: got a 1995 bronco with a leveling kit up front running 33s on alcoas! my 3rd bronco
one of them 2 options for the rear will work awesome with that front end ur throwing at it
- 450xracer68
Short course links I’m guessing?IV95BRONCO wrote:one of them 2 options for the rear will work awesome with that front end ur throwing at it
- 450xracer68
Score!
450xracer68 wrote:Short course links I’m guessing?IV95BRONCO wrote:one of them 2 options for the rear will work awesome with that front end ur throwing at it
Yup LINKS for sure! bitchin u sure did scored on that giant kit & coilovers from fb lol
Nice looking bronco, your plan should have that thing dialed in no time. Can't wait to see how this turns out.
- 450xracer68
Little progress today!
Score I was trying to pick up that stuff glad to see you got it!
- 450xracer68
Been plugging along little by little.
Hung a fender to see what it would look like. Needed some motivation that day lol.
Started tearing apart fenders and started the engine cage.
Drilled hole for the engine cage and started on the shocks today. They are mocked up and will most likely be the final spot unless someone sees something wrong.
Final travel numbers are 18.5” for the driver side and 19” for the passenger side. I could go another 1/4” up on DRS before I hit my cross member. Next will be seeing clearances with my axles in. Just need them to get finished up.
- 450xracer68
Tucked
Ride height should be about 2 inches lower from this point. Kind hard to get a picture in this spot at the shop.
Always wanted to do glass how rough is it to accomplish?
- 450xracer68
It’s not on all the way, I just hung it there. Honestly, the stocks came off fast. It’s putting everything back together is what is going to be fun. I will most likely running the inner fender to keep everything kept in place good.biggiek wrote:Always wanted to do glass how rough is it to accomplish?
- 450xracer68
Work has been crazy, so I have been working on it when I can. Spent a couple days getting it from peices to something that looks semi done lol.
Beams are done and suspension cycled. Everything is in its final spot.
Ran all brake lines with 2 flex lines and AN-3 fittings. Hardline down the radius arm. Fenders got to go but I’m not worried about them.
Measured it out today and she’ll be strapped at 18.5 with no binding.
Steering is next, plan on just extending stock adjusters until I can order my double swing steering. Limit straps and bumps will be ordered by end of the week. My plan is to have it driveable in At least a week! Anybody got the hook up on 35’s? Haha
Big steps man, looks great !!
- funinthesun95
Looking good!
- 450xracer68
Got my bumps in and started to mess around. Don’t know if I’m liking this spot to much and I’m second guessing myself on material choice.
Right now the plan is to box the mounting completely in with 1/8th all around. I have some 3/16 plate just don’t know if it will be enough. Have a feeling the weight of the bronco is going to eat them up. Suggestions?
