Black954's 81 Silver Lake sand dunes build
I would not weld them. If the brackets ever broke (and they do) it would be a pain in the butt to replace them. The bolts hold them in place just fine. It doesn’t matter if they are welded on, if the crossmember is gonna crack, it’s gonna crack.
black954
Bronco Info: 1981 Bronco Ranger
Re: Black954's 81 Silver Lake sand dunes build
Post by black954 »
That's kinda what I was leaning towards. I think I will replace the hardware and just swap back to stock length when I go extended C&T. I am currently welding up the front crossmember and boxing the frame so that's why I asked. It would be easier to weld the drop brackets now with no engine/transmission in. Thank you for the input. On a side note, these Rancho drop brackets are waaaaaay beefier then the stock brackets! I looked at Autofabs stock replacements and they are pretty beefy as well. I'll probably wind up using theirs.
1981 Bronco Ranger
LS3/TH400/Atlas II
35" KM2/Raceline beadlocks
sand dunes build
Are you caging your bronco? I only ask because there is a chance of the frame cracking from being boxed without a cage. The reason is these frames are meant to twist like crazy. I’ve seen frames crack from being boxed. A cage would stiffen it up considerably and you wouldn’t have to worry about a cracked frame.
hollandermotorsports
I would bolt the brackets on but also add a couple .5" to 1" stitch welds that is easily accessible with a cut off wheel. I say this because these beam pivots take a lot of torque especially with the added leverage of a drop down bracket. Unless the holes are overlayed and reamed for perfect fit with properly shanked bolt any movement will damage holes for the future. this is just my .02 cents.
black954
Post by black954 »
Tchajagos wrote:Are you caging your bronco? I only ask because there is a chance of the frame cracking from being boxed without a cage. The reason is these frames are meant to twist like crazy. I’ve seen frames crack from being boxed. A cage would stiffen it up considerably and you wouldn’t have to worry about a cracked frame.
Yes I will be putting in an extensive 4340 cage. I have over 300’ of 2” and 1 5/8 .120” and .095” tubing to work with. I have the early Swiss cheese frame so it will need the extra boxing for sure. I will wind up cutting the roof off to weld the cage. I am also going to run a soft top to eliminate weight. I’m hoping to keep the finished weight under 4,500lbs.
Right now I’m working on installing the solid body mounts. Not very hard but pretty time consuming.
1981 Bronco Ranger
LS3/TH400/Atlas II
sand dunes build
black954
Post by black954 »
hollandermotorsports wrote:I would bolt the brackets on but also add a couple .5" to 1" stitch welds that is easily accessible with a cut off wheel. I say this because these beam pivots take a lot of torque especially with the added leverage of a drop down bracket. Unless the holes are overlayed and reamed for perfect fit with properly shanked bolt any movement will damage holes for the future. this is just my .02 cents.
This is great advice, thank you. There are plenty of spots to stich weld them that are easy to get to with a wafer wheel
1981 Bronco Ranger
LS3/TH400/Atlas II
sand dunes build
black954
Post by black954 »
Here's a couple pics of the solid body mounts. I used zinc plated fender washers underneath the frame mount but I just received some thick stainless body washers to replace the zinc plated ones.
Also, I finally got my plasma cutter this past week. I was waiting on it so cut out the plate used to box the frame.
body mount2.jpg (279.95 KiB) Viewed 2946 times
body mount.jpg (310.87 KiB) Viewed 2946 times
1981 Bronco Ranger
LS3/TH400/Atlas II
sand dunes build
Nice. When I remove old body bushings I found an easy way to get them out. Take out the stock bolt, I put a 2x4 on a jack and jack up on the body bushing nut from underneath. This lifts the metal part of the bushing enough to get a sawzall blade in between the metal and rubber parts of the bushing. That way you don’t have to cut through the rubber.
Another way to get some of them out are to get a long bolt that fits the nut. Remove all body mount bolts and thread the longer bolt in. If you give it a few really really good whacks the bottom of the bushing should pop out. May take some really hard hits.
black954
Post by black954 »
I hope the rest of the body mounts I can try those techniques. On mine, the bolt is rusted to the sleeve so I cannot remove the bolt. Instead I had to sawsall through the sleeve and bolt at the same time.
1981 Bronco Ranger
LS3/TH400/Atlas II
sand dunes build
black954
Post by black954 »
Got a little more progress done over the weekend. I removed the factory frame motor mounts. Then I was able to weld the engine cradle to the frame rails everywhere I could. It actually welded better than I thought it would being that it has 37 years of oil and crud in all the seams.
frame weld5.jpg (290.01 KiB) Viewed 2843 times
frame weld4.jpg (273.75 KiB) Viewed 2843 times
frame weld3.jpg (275.52 KiB) Viewed 2843 times
frame weld2.jpg (234.49 KiB) Viewed 2843 times
frame weld1.jpg (261.25 KiB) Viewed 2843 times
frame brackets.jpg (258.66 KiB) Viewed 2843 times
1981 Bronco Ranger
LS3/TH400/Atlas II
sand dunes build
black954
Post by black954 »
I did find a crack behind the steering box. So next I will be removing the box to weld up the crack. Then I can weld in a reinforcement plate to the steering box mount to hopefully stop it from happening again.
frame crack.jpg (227.34 KiB) Viewed 2844 times
1981 Bronco Ranger
LS3/TH400/Atlas II
sand dunes build
black954
Post by black954 »
I spent some time making a template for the frame rails. Next, I will transfer it to plate and cut it out with the plasma. I'm still undecided if I will cut scallops on the bottom of the plate so that sand and water doesn't get trapped inside the frame causing rot.
frame template.jpg (174.79 KiB) Viewed 2844 times
1981 Bronco Ranger
LS3/TH400/Atlas II
sand dunes build
black954
Post by black954 »
I also filled in the 2 1/2" holes on both sides of the frame rails above the front leaf spring perches.
welded plug.jpg (272.31 KiB) Viewed 2844 times
mag plug.jpg (206.34 KiB) Viewed 2844 times
hole plug.jpg (132.33 KiB) Viewed 2844 times
1981 Bronco Ranger
LS3/TH400/Atlas II
sand dunes build
black954
Post by black954 »
My new cordless Milwaukee 4" grinder is MUCH better than I thought it was going to be. It's got more power then my other corded Milwaukee 4" grinders and it's quieter.
cordless grinder.jpg (210.71 KiB) Viewed 2844 times
1981 Bronco Ranger
LS3/TH400/Atlas II
sand dunes build
black954
Post by black954 »
Question, How are the front rubber bump stops attached to the frame? I couldnt really see a good way to unbolt them or anything
1981 Bronco Ranger
LS3/TH400/Atlas II
sand dunes build
There’s a bolt in the top. Kid of recessed in the first layer of frame rail. I think it’s like a 10mm 12pt or something.
black954
Post by black954 »
Thank you very much. I must have a ton of grease and dirt caked on top to where I couldn't feel it.
1981 Bronco Ranger
LS3/TH400/Atlas II
sand dunes build
