started prepping the rear cargo area for the last 2 bottles of liner. Gonna leave the cage #Steelit and rest will be liner. Ran outta daylight, gonna hopefully spray tomorrow.
Bajaluv wrote:While she was getting her tranny back in and all buttoned up I decided to use the time to install the refurbished tilt steering column. Topped it with a wheel I picked up from Taylor about 8 months ago. I now have Zero play in my steering, sooooo nice. Added a bigger pan so 18 quarts for the tranny and ruffly 2 for the transfer case she was back on the road. I'll check fluid in the morning and add if needed. Oh and a 87-91 bronco does NOT need a VSS kit.
westco wrote:Bajaluv wrote:While she was getting her tranny back in and all buttoned up I decided to use the time to install the refurbished tilt steering column. Topped it with a wheel I picked up from Taylor about 8 months ago. I now have Zero play in my steering, sooooo nice. Added a bigger pan so 18 quarts for the tranny and ruffly 2 for the transfer case she was back on the road. I'll check fluid in the morning and add if needed. Oh and a 87-91 bronco does NOT need a VSS kit.
Hi Aaron,
I bought the underbody mount from you a few weeks ago, where did you get the refurbished column?..thanks JP
Hi - can you tell me where did you get those bolts and nuts, and what size are they? Thx.Bajaluv wrote:So went ahead and cleaned up the sheet metal edges and prepped for Raptor liner. Used bottle and a 1/2 per side. Pretty happy with the turn out, stuff seems pretty thick. Charged up shocks, bumps and she’s getting closer.
Bobby Velazquez wrote:Hi - can you tell me where did you get those bolts and nuts, and what size are they? Thx.Bajaluv wrote:So went ahead and cleaned up the sheet metal edges and prepped for Raptor liner. Used bottle and a 1/2 per side. Pretty happy with the turn out, stuff seems pretty thick. Charged up shocks, bumps and she’s getting closer.
Bobby Velazquez wrote:My bad... I was referring to your wheels bolts and nuts (zinc plated), what size are they and where did you get them? Thanks.
