Cactus Cooler
Post by Cactus Cooler »
black954 wrote:I'm kind of at the same point. Degreased engine bay, LS3 on a stand, still gathering last parts to put it in. Plus mines an 81' so I want to box my frame before I put the drivetrain in. I will start a build thread once I get back on it. I moved houses and am building a big garage currently. Once I get the electric run to the garage, I will be right back on the Bronco.
Any chance you can take a measurement from the front of the bell housing to the yoke of the Atlas ( front to rear)?? Wanted to see how much of a difference from your setup vs a E4OD and stock transfer case? Thanks!
Was throwing this idea around but the cost difference between the ford vs chevy???
black954
Bronco Info: 1981 Bronco Ranger
Post by black954 »
Will do. I'll get one when I get back into the garage in the next day or two.
1981 Bronco Ranger
LS3/TH400/Atlas II
35" KM2/Raceline beadlocks
sand dunes build
