Custom Fuel Pump Hanger- Plate or Not
Hello All,
I made a bracket to hold the new Walbro 255lph fuel pump in place and I made it out of mild steel- should I have this like nickel plates so it won't rust, leave it bare mild steel, I'm pretty sure powdercoat won't last or the nuclear option and remake in SS?? Gas tanks rust out all the time but that's after many years.
Thx,
Matt
Thx,
Matt
- IMG_9725.JPG (112.78 KiB) Viewed 2160 times
- IMG_9726.JPG (116.72 KiB) Viewed 2160 times
Re: Custom Fuel Pump Hanger- Plate or Not
With it being submerged much of the time I think you MAY be fine IF you fill your tank often & don't let the truck sit with half a tank very much.
My concern would be all the surface rust/crap that will accumulate on the plate when the truck has half a tank & half the bracket is exposed to the air. Then that crap gets washed off when you fill & it floats around until it gets stuck in the pump or filter.
If if were me I'd make it out of 316 stainless.
Stop over-thinking it. Put it back in and go play.
LvSteve
No finish is needed, make sure it clean when installed
It you're going to remake, use aluminum. Then it wont need to be coated.
I made a bracket for same scenario...puts fuel pump sock at same point as oem and is also adjustbale if your tank is smashed in like I have had in past. Bolts on just like factory pump but uses 1/4-20 hardware.
I have a couple extras I would sell for $25ea
- IMG_4112.jpg (76.22 KiB) Viewed 2014 times
- IMG_4111.jpg (75.28 KiB) Viewed 2014 times
Interested can you text me a price with shipping and your PayPal infop
What about the sending unit?
Mine is a completely different scenario being a F150 but this looks nice
theyre gone via pm's i saw before this reply.cs_drums wrote:Interested can you text me a price with shipping and your PayPal infop
sending unit is all factory. unbolt big plastic pump, bolt on this bracket using same screw holes.VintageIronFab wrote:What about the sending unit?
Bummer. I have a 255lph pump siting in a box cause I’ve been lazy about making one of these haha
I'll take one if you do another run on them.
I was gonna say - based on the pic that's a cad drawn & cut part. I'm sure Kris could get some more cut.
Personally $25 is too cheap- I’d say make it $60 shipped and make it a worth his time because I really want one! I’d rather stay at work a little longer than screw with making one! Come on Kris make another round go help pay for that 408!!
Anyone who has one of these brackets from Kris and didn’t install it - I’ll give you $60 for it or let me borrow one for dimensions so I can build one!
Make a few, I'll buy one.
I’ll buy one
Well I’m not sure who bought it or them from Kris but however that is I want to buy that from Kris or borrow it to knock off - Kris is seemingly not doing anything more with these but I want to! Get in touch with me!
Following closely. Now days there are several companies selling costly drop in setups, but a Diy setup is promising.
Going to need something like being discussed in the near future.
