Edelbrock 5.8 lower intake manifold
I am getting ready to install the lower manifold and came across an issue on how to proceed. The rear has what I determined to be a provision for a PCV when installing onto a mustang and not a bronco. For the bronco what should I do with it? It came with a block off plate but it more restricts the flow and doesn't block the entire port. Any help would be great see the image attached.
- 20171229_124713.jpg (541.25 KiB) Viewed 1299 times
Looks more like an oil baffle. Not a block off plate.
What does the other side look like?
LvSteve
Re: Edelbrock 5.8 lower intake manifold
Lightnings and Rc51 came that way.
It is for the pcv. It is a baffle,
Run it or block it with a plug.
Valve cover set up is cleaner for your upper intake in the long run
What Eddy part number are you playing with ?
I am playing with 3884 for the lower and that is what I figured. Any reccomendation for a plig?
- s-l225.jpg (6.1 KiB) Viewed 1247 times
It's non threaded.
LvSteve
I have used plastic valve cover plug. It working to get it running. Not recommended.
Steel or aluminum plug. Like a freeze plug
The screw in style aluminum plug is what I like the best
Do you have to smog ? Are you going to run a EGR system
I am going to run the egr systems as emissions is a requirement in AZ. I like the idea of a freeze plug just need a good auto parts guy to help get me a correct diameter.
a pair of dial calipers or measuring tape will work.
