1995 F-150 Build
S00TLYFE
Bronco Info: IT RAPTOR NOW
1995 F-150 Build
Post by S00TLYFE »
A lot of you guys already know, but I picked up a super clean F-150 a few weeks ago.
1995 302/Auto with 184,000 miles. The truck still passes smog and the AC blows ice cold. I have all the stuff to convert it to 4x4 which I will probably do after desert season is over. As of right now shes on track to make me all over Baja for the 50th 1000 next week.
Re: 1995 F-150 Build
Pictures.....!
S00TLYFE
Post by S00TLYFE »
S00TLYFE
Post by S00TLYFE »
Jack approves of being able to ride in a truck again
S00TLYFE
Post by S00TLYFE »
Went ahead and swapped my Corbeaus in though because i picked up an expedition console I plan on swapping on for my race radio and GPS (not going to have time to get it done before the 1000 though.
S00TLYFE
Post by S00TLYFE »
Decided to throw my ttb stuff under this truck with some 5100s and deavers so I can drive this thing to mexico next week.
S00TLYFE
Post by S00TLYFE »
i really hate not being able to edit posts because i accidentally sent that out of order but you guys get the idea.
zachwabbit
Post by zachwabbit »
Dang I need to get off my butt and tear down mine!
Potato.
Super nice truck- whatever you do keep it stock width!
S00TLYFE
Post by S00TLYFE »
VintageIronFab wrote:Super nice truck- whatever you do keep it stock width!
That's my ideal goal. Mild build, super clean, stock width.
We'll see what happens but that's what my goal is. As long as it can get me down to baja for beer and tacos I'm happy with it.
Well the Autofab basically stock width fenders are super cool and fit great. If I️ had gone that route- THOUSANDS still would be in my account and months of work saved!!!
Joshmellor19
Bronco Info: 1995 f-150 std cab short bed 5.8 automatic
Post by Joshmellor19 »
Any plans for the rear? I like the wheel and tire setup btw!
S00TLYFE
Post by S00TLYFE »
Joshmellor19 wrote:Any plans for the rear? I like the wheel and tire setup btw!
I actually have a set of F53 deavers at deaver getting freshened up that will go on the rear along with Taylor (nubreed) old coilovers and bypasses, not sure if I'll have time to get them on before the 1000 tho.
S00TLYFE
Post by S00TLYFE »
VintageIronFab wrote:Well the Autofab basically stock width fenders are super cool and fit great. If I️ had gone that route- THOUSANDS still would be in my account and months of work saved!!!
Haha I hear ya dude I feel like you might as well count on about 15k minimum in additional spending the second you decide to go wider.
F1Brendan
Bronco Info: It's a non Bronc! the bronco's larger cousin with a bed, a 95 f1
Post by F1Brendan »
Super clean truck dude! You never see these things in silver either.
I can say that the 38 gallon rear tank is super easy to install and makes it easy to ditch the front factory tank if you choose which really opens up the rear shock placement on the upper mount.
S00TLYFE
Post by S00TLYFE »
F1Brendan wrote:Super clean truck dude! You never see these things in silver either.
Thanks man I appreciate it
S00TLYFE
Post by S00TLYFE »
VintageIronFab wrote:I can say that the 38 gallon rear tank is super easy to install and makes it easy to ditch the front factory tank if you choose which really opens up the rear shock placement on the upper mount.
That's definitely on my list of things to do, how does the line situation work though? Just cap off the stuff for the front tank?
Haven't looked SUPER closely but I haven't found a good write up on it yet.
There’s a couple ways to do it. I cut the tit off at the block where the lines go to
The front pump and welded up the hole but wouldn’t do that again. Personally cut before and after the block of sorts where the line goes to the front pump, slide a tube nut and sleeve over the line, single flare and put a -6an male/male fitting in to connect the two lines.
S00TLYFE
Post by S00TLYFE »
VintageIronFab wrote:There’s a couple ways to do it. I cut the tit off at the block where the lines go to
that seems easy enough, already got a bronco tank too and deleted the spare tire carrier
