Belt sanders and drill press
I'm helping my aunt sell of some of my grandfather's old tools. All of this stuff was light use in a personal shop. My grandfather was a carver & used used the sanders to shape pieces.
This stuff is currently located on Balboa Island in Newport Beach, but I can get it to Huntington to my place if that would help
1st tools is a 6"x48" belt & a 9" disc sander combo on a stand. Has a 3/4 HP motor that is 110v or 220v single phase. Build date 1986. Made by A. J. Tools "Pit Bull" - made in Taiwan. Couldn't find any info on this brand, but I'm assuming it may be similar to harbor freight, although it seems a little better. Quality brand sanders like this are in the $450-500 range. Harbor freights is $220, so I'll ask $150. We may have some spare belts & disks around which you can have with it if we come across them.
2nd is a smaller sander. It's also an A. J. Tools "Pit Bull" - made in Taiwan. It's a 1"x42" belt & a 6" (may be an 8"??) disc sander combo. Has a 1/2 HP motor that is 110v single phase. Build date 1986. There should be extra sanding belts around to go with this one. Jet's version of this looks to be $400 and the Grizzly version is $115 so I'll ask $60 for this one.
Notice the error on disk size? Plate shows a 1x8"belt & 42" disk...
Last is a sweet, OLD, Rockwell Delta "Homecraft" drill press. From my research it sure looks like an 11-120, 11" press. Made in the 40's. I'd love to hang on to this for the history & shear cool factor of it, but my garage is already over stuffed with tools I hardly get to touch anymore... Asking $100 for this
Re: Belt sanders and drill press
Photos for the drill press.
I check this board regularly, so I'll see replies here, but if calling/texting works better for you feel free. 9four9 three78 3553
I really want the bigger sander. Any way it can get a bit closer to San Diego. My truck is blown up and I doubt it will fit in my bronco.
I don't get down toward San Diego at all, but maybe someone else on here runs between OC & SD & we can do a parts train. I'll get some dims on it to see how big it is & then also try & look at if the base/stand would come off fairly easily or not.
On a side note, I know there is a router table a grinder and also a shopsmith I will be needing to look at & part with in case anyone is interested.
Here's a pic I just got of the grinder. Has a drill bit sharpening attachment on it. Not sure what to ask on this one. Need to look at it a bit.
I'm trying to get the tools here to HB for easier pickup. Will see what I can do on that.
What's a shop smith?
Kind of an all in one shop tool. Pretty cool if you haven't seen one before, but more for wood working than metal
https://www.google.com/search?q=shopsmi ... 80&bih=917
https://orangecounty.craigslist.org/tls ... 37035.html
A little more on the grinder. It is a delta "homecraft". Looks to be from the 40's, maybe 50's based on the "art deco" body/housing on it. Has a drill grinding attachment on it. Asking $50 from GFB guys. Putting on CL for $75 to start.
These tools (and even more) are now in my possession so I have better pics and can answer more questions since I can look at the things.
Smaller sander is an 8" disk and there are a few spare belts
Both sanders & the grinder all currently pending.
Couple more pics for the drill press and it's motor
I'd be interested in the smaller sander if the parts train can come down to San Diego
Smaller sander pending = as soon as I can meet up with Will - most likely this weekend. I'll let you know if anything changes there though.
Small sander and grinder officially gone. Larger sander pending pickup still.
- S00TLYFE
- Bronco Info: IT RAPTOR NOW
interested in the drill press. if you have it ill pick up sometime in the next week. ill text you tomorrow evening when i get back from the bay area
Sounds good. It's still here. I was gone for 10 days and with that & the holiday I haven't really kept the thing actively listed elsewhere
Drill press is now gone too. So everything here has now been sold
