These roof racks are designed specifically for the 80-96 Bronco. They are constructed of 5058 aluminum panels with steel cross tubes for storage support. Available in raw aluminum or powder coated black. Light bar brackets included. Offered at an additional cost is ARB's 4' awning that we can fit to the back of the rack for some shade cover. Racks start at $649 CLICK HERE to order and for product page.
It bolts through the top on all 4 corners. We have tapered pads that fit the length of the rack and the curve of the roof between the fiberglass top. The rack is really easy to assemble. Bolt the cross tubes to one side panel and then the other, and then bolt the front and rear panels and light bar bracket if you are using it.
mikeleung wrote:Nice rack. Any way to mount LED lights on the side and rear?
Sorry for the delayed response, shops been busy!
Yes there are holes on the top of the side panels for straps and rear panel where you could easily attach your lights.
